> 2056 seized
tpines
post Nov 11 2025, 12:15 PM
Hi guys,
Just to let you know I am heart broken as my rebuilt 2056 with only 6,000 miles seized last week. Apparently, I ran it low on oil.
Now, I'm not the most mechanically inclined but I changed the oil in July after after putting 3,000 annual miles on it. Since it was a new motor I didn't think I needed to check the oil every couple of weeks like my mechanic told me.
How often should you check the oil level with a new motor? And do you think it's going to need a full rebuild again?
930cabman
post Nov 14 2025, 01:19 PM
Losing an engine is never a good thing, and it really sucks I'm sure.
How did it run out of oil? smoking, dripping on the ground
porschetub
post Nov 14 2025, 05:31 PM
QUOTE(930cabman @ Nov 15 2025, 07:19 AM) *
I don't believe the oil went back in ,its simply not down to oil consumption or leaks ,both of would have been very evident in 800 miles .
I would expect lack of oil would have done a fair amount damage internally
Edited due to incorrect ,misleading info , and thanks Jack for pointing that out .
Cheers.
tpines   2056 seized   Nov 11 2025, 12:15 PM
GregAmy   Oof that sucks. Honestly, I check my 914's oi...   Nov 11 2025, 12:20 PM
JamesM   Honestly, I check my 914's oil level each ti...   Nov 11 2025, 09:06 PM
trojanhorsepower   Oh man, so sorry about this. I have a new 2056 an...   Nov 11 2025, 01:41 PM
JamesM   It is odd that it would have leaked down that mu...   Nov 11 2025, 09:09 PM
Chad911sc   I have a 2056 as well and it’s torn down for the...   Nov 11 2025, 01:52 PM
trojanhorsepower   Mine has lower oil pressure than I would like. Ap...   Nov 11 2025, 02:35 PM
emerygt350   I was just looking through that porsche technical ...   Nov 11 2025, 03:57 PM
wonkipop   I was just looking through that porsche technical...   Nov 11 2025, 04:47 PM
JamesJ   I was just looking through that porsche technical...   Nov 11 2025, 08:04 PM
Geezer914   I check my oil before each use. I just pulled the...   Nov 11 2025, 05:25 PM
Front yard mechanic   I change my oil every day ! A drip at a time i...   Nov 11 2025, 05:50 PM
tpines   Thanks for all of your input guys. The oil light n...   Nov 11 2025, 10:16 PM
Jack Standz   Very very sorry to hear about the engine failure, ...   Nov 12 2025, 07:41 AM
Superhawk996   Story doesn’t add up 6000 miles total prior to...   Nov 12 2025, 08:59 AM
Ninja   :agree: I consider a failure at this mileage as ...   Nov 12 2025, 09:08 AM
VaccaRabite   I agree. There was some sort of mechanical fault ...   Nov 12 2025, 09:59 AM
Jack Standz   Story doesn’t add up. I would not let whoever...   Nov 12 2025, 10:03 AM
Superhawk996   Story doesn’t add up. I would not let whoeve...   Nov 12 2025, 10:27 AM
emerygt350   what happens when you over-torque that oil screen?   Nov 12 2025, 11:09 AM
Superhawk996   what happens when you over-torque that oil screen...   Nov 12 2025, 12:56 PM
tpines   So I went back over all my records: Original 2.0 ...   Nov 12 2025, 10:50 PM
mepstein   You said you apparently ran low on oil. How low? H...   Nov 13 2025, 06:08 AM
tpines   There was probably half a quart to a quart left in...   Nov 13 2025, 08:51 AM
mepstein   There was probably half a quart to a quart left i...   Nov 13 2025, 09:06 AM
sixnotfour   somebody forgot to Add oil...   Nov 13 2025, 09:08 AM
GregAmy   That’s a lot of oil loss in (if I read correctl...   Nov 13 2025, 09:16 AM
mepstein   That’s a lot of oil loss in (if I read correct...   Nov 13 2025, 10:02 AM
GregAmy   It happens... Remember, you're replying to t...   Nov 13 2025, 09:36 PM
davep   I am very sorry to hear of your engine failure, an...   Nov 13 2025, 09:24 AM
Ninja   Kept stock cam and fuel injection Hydraulic lift...   Nov 13 2025, 09:35 AM
emerygt350   I wonder if you filled it with penetrating oil, dr...   Nov 13 2025, 09:49 AM
Geezer914   Who did the oil change?   Nov 13 2025, 09:56 AM
Jack Standz   There was probably half a quart to a quart left ...   Nov 13 2025, 10:27 AM
Artfrombama   Since it was a new motor I didn't think I nee...   Nov 13 2025, 10:31 AM
Ottomotion   If the motor failed due to oil starvation, the oil...   Nov 13 2025, 07:22 PM
wonkipop   If the motor failed due to oil starvation, the oi...   Nov 13 2025, 11:51 PM
FlacaProductions   I'm wondering if there was any in it to start ...   Nov 13 2025, 09:15 PM
tpines   Thank you all again for all of your advice.. I...   Nov 13 2025, 10:44 PM
930cabman   Losing an engine is never a good thing, and it rea...   Nov 14 2025, 01:19 PM
porschetub   Losing an engine is never a good thing, and it re...   Nov 14 2025, 05:31 PM
Jack Standz   Losing an engine is never a good thing, and it re...   Nov 14 2025, 02:42 PM
Jack Standz   Losing an engine is never a good thing, and it r...   Nov 14 2025, 06:30 PM
rick 918-S   my guess.. dropped a valve seat.   Nov 14 2025, 08:18 PM
930cabman   Seized engine = will not turn over (spin) Open i...   Nov 15 2025, 02:41 PM
rbzymek   So even with the oil filled to the top mark I used...   Dec 5 2025, 08:35 AM
- Lo-Fi Version Time is now: 14th March 2026 - 01:47 AM
