> Mystery Wipe, Still have …..?
jim_hoyland
post Aug 20 2009, 09:34 PM
Get that VIN ?
I have an intermittant relay installed. I continue to get mystery wipes when makiing a sharp turn--not always, just occasionally. These mystery wipes seem to always occur when the windshield has just enough grime to really mess up the view.
OK: Could I be grounding the wiper switch when turning the wheel, or does the intermittant relay just go bonkers and give free wipes at its descetion ? (IMG:style_emoticons/default/confused24.gif)
Who's figured this out ?
914Sixer
post Nov 16 2025, 08:25 AM
Nothing comes to mind right off
jim_hoyland   Mystery Wipe   Aug 20 2009, 09:34 PM
Kirmizi   Pull the center hub and check your contacts/wires ...   Aug 20 2009, 09:46 PM
jim_hoyland   Pull the center hub and check your contacts/wires...   Aug 20 2009, 09:58 PM
Kirmizi   Hell, now that I think about it, the wipers could...   Aug 20 2009, 11:28 PM
ClayPerrine   It could also be in the wiper motor. There is a c...   Aug 21 2009, 10:32 AM
jim_hoyland   Update: I replaced the relay several months ago an...   Jun 27 2012, 06:57 PM
76-914   Thx for the tip, good to know.   Jun 27 2012, 07:13 PM
scotty b   Thx for the tip, good to know. I was relieved t...   Jun 27 2012, 07:23 PM
monkeyboy   Thx for the tip, good to know. I was relieved ...   Jun 27 2012, 09:47 PM
Bartlett 914   Your problem is a loose ground connection. This co...   Jun 28 2012, 08:16 AM
Bartlett 914   Here is the backside of the switch. You can see th...   Jun 28 2012, 08:21 AM
jim_hoyland   Here is the backside of the switch. You can see t...   Nov 21 2025, 02:25 PM
jim_hoyland   Follow up: Read a post that recommended tightening...   Nov 14 2025, 07:49 PM
914Sixer   Nothing comes to mind right off   Nov 16 2025, 08:25 AM
jim_hoyland   Next: gonna check that ground on the back of the w...   Nov 16 2025, 03:17 PM
jim_hoyland   See post 10 and 11…. @bob164   Nov 17 2025, 07:01 PM
Front yard mechanic   If you ask chat gpt what mystery wipe is Jim’s n...   Nov 21 2025, 09:32 PM
914Sixer   Sending Jim a different wiper switch to play with.   Nov 22 2025, 10:57 AM
- Lo-Fi Version Time is now: 7th March 2026 - 12:22 AM
