> Installing CSP carb linkage
burlybryan
post Apr 14 2025, 06:59 PM
I have a hex bar linkage and I want to install a CSP linkage. Do you think I can reuse my existing throttle cable bracket and cable? The orientation/angle appears like it should work, but wanted to check because I figure someone else has done this before.
Thanks!
Bryan
neyen14
post Nov 16 2025, 04:16 PM
Can anyone with CSP linkage to dual Weber's please post pics?... the pics on the directions they sent aren't clear.
1. It looks like the directions say to remove the idle speed screw but doesn't say put it in the front of the carb, is the set up solid enough to only need one idle speed screw?
2. I have the linkage bars to each carb in the most direct lines.... I would have to put the gas pedal in the rear targa compartment to accelerate.... Sumting wong
3. #1 and #3 plug wires in the way
- Lo-Fi Version Time is now: 17th November 2025 - 08:34 PM
