| didenpx |
Nov 16 2025, 03:08 PM
Member ![]() ![]() Group: Members Posts: 92 Joined: 1-September 23 From: Usa Member No.: 27,556 Region Association: North East States
I have my engine out (75 1.8 fwiw) and am trying to remove the cooling fan with no luck. I have a puller and it doesn’t budge, but I also was conservative on torquing because I’m afraid of stripping threads. Is there some hidden trick to this? I’ve got the hub basting in PB Blaster while I consult you gurus.
TIA Paul |
| didenpx |
Nov 16 2025, 05:43 PM
Thanks; I will add heat and tapping to the routine.
didenpx Engine Cooling Fan Stuck? Nov 16 2025, 03:08 PM
930cabman can you put some heat on the aluminum hub prior to... Nov 16 2025, 05:03 PM
burton73 When you put a lot of penetrating oil or product o... Nov 16 2025, 05:13 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th November 2025 - 08:33 PM |
