| burlybryan |
Apr 14 2025, 06:59 PM
Member ![]() ![]() Group: Members Posts: 139 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None
I have a hex bar linkage and I want to install a CSP linkage. Do you think I can reuse my existing throttle cable bracket and cable? The orientation/angle appears like it should work, but wanted to check because I figure someone else has done this before.
Thanks! Bryan ![]() |
| MedFly914 |
Nov 17 2025, 11:20 AM
Newbie ![]() Group: Members Posts: 48 Joined: 10-July 20 From: Alhambra Ca Member No.: 24,478 Region Association: Southern California |
Dual Weber 44's
burlybryan Installing CSP carb linkage Apr 14 2025, 06:59 PM
porschetub
I have a hex bar linkage and I want to install a ... Apr 14 2025, 10:03 PM
914werke Itll work! Apr 14 2025, 11:09 PM
930cabman I have several hex bar setup's on the shelf, n... Apr 15 2025, 04:55 AM
Spoke
Do you think I can reuse my existing throttle cab... Apr 15 2025, 06:04 AM
burlybryan Thanks guys. I'll give it a go. I have a spa... Apr 15 2025, 08:15 AM
neyen14 Can anyone with CSP linkage to dual Weber's pl... Nov 16 2025, 04:16 PM
neyen14
Can anyone with CSP linkage to dual Weber's p... Nov 16 2025, 04:39 PM
mjrrti I think you need to rotate the bell crank 180 so t... Nov 17 2025, 01:13 AM
neyen14
I think you need to rotate the bell crank 180 so ... Nov 17 2025, 12:15 PM
MedFly914 Oops, this pic is with the 40 Dellortos. Nov 17 2025, 11:24 AM
MedFly914 With Webers Nov 17 2025, 11:33 AM
neyen14
With Webers
Thank you. Like the other member me... Nov 17 2025, 12:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th November 2025 - 08:35 PM |
