> help-oil strainer won't come out
dlindzey
post Nov 18 2025, 03:44 PM
repeat offender
I am changing oil and got stuck at the oil strainer. The outer piece has come off and i have removed the paper washer that was under it. It was not easy to pull the outer piece off.
I removed what I will call an odd nut that connects to a stud that is now sticking out of the retained portion of the oil strainer. The strainer appears to be aluminum. I can not dislodge this inner piece to get to the strainer and to complete the job as intented.
Is this a common issue? Any solution/ Naturally not forcing the issue.
Superhawk996
post Nov 18 2025, 07:48 PM
The other thing that happens is they get hung up on the stud threads. Cheap strainers aren’t made well and often have crappy fit at the studs with sharp edges getting deformed into the threads. Sometimes useful to spin it as if you are unthreading the strainer - even though it’s not threaded. Attached Image
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: Superhawk996
- Lo-Fi Version Time is now: 19th November 2025 - 02:17 AM
