| dlindzey |
Nov 18 2025, 03:44 PM
repeat offender ![]() ![]() Group: Members Posts: 51 Joined: 8-April 14 From: texas Member No.: 17,226 Region Association: Southwest Region |
I am changing oil and got stuck at the oil strainer. The outer piece has come off and i have removed the paper washer that was under it. It was not easy to pull the outer piece off.
I removed what I will call an odd nut that connects to a stud that is now sticking out of the retained portion of the oil strainer. The strainer appears to be aluminum. I can not dislodge this inner piece to get to the strainer and to complete the job as intented. Is this a common issue? Any solution/ Naturally not forcing the issue. |
| dtmehall |
Nov 18 2025, 07:54 PM
Member ![]() ![]() Group: Members Posts: 208 Joined: 21-December 23 From: Farmington Hills, Michigan Member No.: 27,808 Region Association: Upper MidWest |
as noted above, there is a danger in prying with scratching the sealing surfaces.
you can use a screwdriver, but be careful where you put the fulcrum point you can also use a SMALL blade tool to get between the opening in the strainer and pull straight down good luck! |
dlindzey help-oil strainer won't come out Nov 18 2025, 03:44 PM
Shivers Which piece will not come off?
@[url=http://ww... Nov 18 2025, 05:58 PM
dlindzey
[b]@[url=http:... Nov 18 2025, 07:15 PM
dlindzey
dlindzey
dlindzey
dlindzey
fiacra A picture would be helpful. It could just be me b... Nov 18 2025, 06:16 PM
Shivers Is it number 12? :lol4: Nov 18 2025, 07:32 PM
Shivers It is a replaceable part, about 20 bucks. Maybe so... Nov 18 2025, 07:39 PM
bkrantz If you try prying out the strainer, be careful not... Nov 18 2025, 07:48 PM
Superhawk996 The other thing that happens is they get hung up o... Nov 18 2025, 07:48 PM
fiacra Yeah, been there as well. There's nothing sec... Nov 18 2025, 10:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th November 2025 - 02:18 AM |
