> Faulty Voltage Regulator?
Rob-O
post Nov 22 2025, 08:44 AM
About a month or so ago I replaced my alternator. The old alternator was a GM one wire unit with an internal VR that was attached using a modified mount. I think the heat killed it. When in installed the new (rebuilt) alternator I used a new alternator wiring harness and also installed an NOS voltage regulator onto the relay board. When I fired the car back up after install everything worked as advertised. In the last few days though I’ve noticed that when I first start the car that sometimes the voltage fluctuates. I thought it may have just been the gauge in the center console so I broke out the DVM. Readings showed that sometimes when I start the vehicle the volts hover steadily around 13.8v. Other times the voltage fluctuates from just above 12.0v to just over 15.0v. When the voltage spikes high I hear noise coming from the engine bay. I know it’s not but it sounds like a bearing running without lubricant. When the voltage drops to normal levels the noise goes away. Voltage spikes and noise comes back. I don’t have an extra VR handy but does this sound like a faulty VR? It is an NOS unit so not a newer style solid state.
emerygt350
post Nov 22 2025, 09:13 PM
Yeah, double check the belt. I have had a loose belt result in that. If that isn't it, just go buy the digital and adjustable VR off Amazon. I have tried multiple nos and new vrs and none of them come close to the reliability of the Volvo adjustable VR.
https://www.amazon.com/dp/B014GN1YLK?ref=pp...op_mob_ap_share
dtmehall
post Nov 22 2025, 09:32 PM
QUOTE(emerygt350 @ Nov 22 2025, 10:13 PM) *
(IMG:style_emoticons/default/blink.gif)
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 23rd November 2025 - 01:55 AM
