> Recommendations for inch pound torque wrenches
fiacra
post Nov 23 2025, 09:35 AM
Person.Woman.Man.Camera.TV. = MCI
Several recent threads about oil screens has me thinking I need to invest in another tool - a torque wrench that is more accurate at the lower end of scale. To that end, seeking recommendations for which inch pound torque wrench to buy. What do you have and would you recommend it? I suspect there will be lots of different opinions, but lets hear them!
Superhawk996
post Nov 23 2025, 12:40 PM
I’m going to (IMG:style_emoticons/default/stirthepot.gif)
While torque wrenches are necessary tools and should be used there is a deeper problem I’ve seen over 40 years of playing with cars and watching others do the same. I’ve almost always owned Japanese and European cars while my friends owned Domestic stuff.
The biggest issue is the guys that grew up on Murican’ iron seem to think more force (or torque) is the solution to almost every problem. The BFH or the breaker bar come out of the tool box almost as a first choice. Not trying make fun of anyone - just an observation I’ve seen over and over.
That may have some merit when dealing with steel and cast iron. Euro and Japanese stuff tends to involve a lot more aluminum and magnesium. Fasteners tend to be M6 and M8 instead of 3/8 and 1/2”. These differences don’t lend themselves to the BFH and/or more torque approach.
A torque wrench won’t always save you when you don’t have an experienced feel for how much torque a fastener can take. Blind use of torque wrenches can still lead to failure. Especially if you’ve got the wrong spec and don’t have expertise to either recognize the spec seems wrong or don’t have the “feel” of when too much torque is being used.
So how to get that experienced feel for how much torque fasteners can take if you haven’t already learned it working on cheap stuff like bicycles, lawnmowers, and mini-bikes?
Consider this skill builder:
Go buy some simple scrap metal or angle iron. About 1/8” thick steel is perfect.
Put two pieces of it back to back and drill a bunch of holes. 4mm, 6mm, 8mm and 10mm through both parts.
Now go buy a bunch of bolts and nuts of those sizes - like 3-4 of each.
Bolt them up and now we’re going to intentionally over torque them.
Get a feel for what it feels like then the joint first goes hard when the two pieces of angle iron make initial solid contact. .
Then keep applying more torque incrementally until you can feel the fastener beginning to yield. See if you can then back off the torque - inspect the threads. Then do it again and again until you can really feel when that initial yield is starting to happen.
Likely you’ll screw it up and actually strip fasteners - good. Now you’re getting a feel for what is too much torque.
Rinse, lather & repeat until you can reliably start to feel the fastener just beginning to fail so that you can stop just short of the catastrophic damage.
Want more experience?
Repeat the exercise putting gasket material between the angle iron pieces to soften up the joint. It will substantially change the “feel”.
Ready for the advanced class?
Drill and tap the appropriate holes in Aluminum. Again- will have a different feel just prior to failure.
And the PhD?
Repeat these exercises with and without oil on the fasteners. You’ll quickly discover that when fasteners are lubricated it takes a whole lot less torque to fail. a torque wrench won’t save you if the torque spec is for a dry fastener (most are) and you’ve applied anti-sieze.
I know this seems silly but for those that haven’t already earned the experienced “feel” via the school of hard knocks (IMG:style_emoticons/default/headbang.gif) it is far less costly and time consuming than damaging parts on the car.
Now get back to your Amazon shopping (IMG:style_emoticons/default/biggrin.gif)
fiacra   Recommendations for inch pound torque wrenches   Nov 23 2025, 09:35 AM
FlacaProductions   Great question - I don't have an answer and I...   Nov 23 2025, 10:10 AM
sixnotfour   I have a 3/8 drive 40-200 inlb Snap-On, 25yrs old ...   Nov 23 2025, 10:11 AM
TRP   Worth every penny   Nov 23 2025, 10:33 AM
FlacaProductions   On the SnapOn: • Accurate to ±4% clockwise and ...   Nov 23 2025, 10:54 AM
fiacra   On the SnapOn: • Accurate to ±4% clockwise and...   Nov 23 2025, 12:12 PM
JeffBowlsby   I have Craftsman ft-lb and in-lb from 20 yrs ago, ...   Nov 23 2025, 12:02 PM
fiacra   I have Craftsman ft-lb and in-lb from 20 yrs ago,...   Nov 23 2025, 12:15 PM
Dave_Darling   I have Craftsman ft-lb and in-lb from 20 yrs ago...   Nov 25 2025, 11:17 PM
Superhawk996   I’m going to :stir: While torque wrenches are...   Nov 23 2025, 12:40 PM
Ninja   I have over a quarter million worth of tools and I...   Nov 23 2025, 01:08 PM
Ninja   I’m going to :stir: While torque wrenches ar...   Nov 23 2025, 01:29 PM
TJB/914   [quote name='Superhawk996' post='3233918' date='N...   Nov 23 2025, 02:02 PM
dgw   Tom, getting old is a bitch :unsure: I agree, b...   Nov 25 2025, 09:28 PM
Ninja   Tom, I feel your pain! And I'm not yet 65...   Nov 23 2025, 02:21 PM
TRP   This is what I currently have. I had the two Cr...   Nov 23 2025, 03:00 PM
Ninja   Sooner or later, you will... Check out the pair I...   Nov 23 2025, 03:11 PM
914werke   So Ill chime in here. Most every Avg garage shoul...   Nov 23 2025, 04:13 PM
fiacra   So Ill chime in here. Most every Avg garage shou...   Nov 23 2025, 06:27 PM
chmillman   This thread was very interesting, it caused me to ...   Nov 27 2025, 04:56 AM
sixnotfour   Great research :beer2: Many things you mention ...   Nov 27 2025, 06:20 AM
JeffBowlsby   Begs the question on how to correctly torque our a...   Nov 27 2025, 09:25 PM
chmillman   Begs the question on how to correctly torque our ...   Nov 28 2025, 04:25 AM
chmillman   So I was curious and ordered one of the 0.9-60 Nm ...   Nov 28 2025, 12:12 PM
- Lo-Fi Version Time is now: 1st April 2026 - 06:26 PM
