| rfinegan |
Sep 20 2025, 09:55 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,189 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
How are people fitting the Ljet intake manifolds to work with 2.0L heads? FWIW this will be on my 2056.
| Geezer914 |
Sep 24 2025, 09:51 AM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,240 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
I am running a 2056 with Ljet FI. Installed a 50mm Vanagon modified throttle body and modified the snorkel on the air cleaner box. Moved the large wheel one notch richer on the air flow meter. Running HAM heads and 9.0 CR. Runs like a bat out of hell!
| JamesJ |
Nov 24 2025, 11:41 PM
Member ![]() ![]() Group: Members Posts: 268 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California
I am running a 2056 with Ljet FI. Installed a 50mm Vanagon modified throttle body and modified the snorkel on the air cleaner box. Moved the large wheel one notch richer on the air flow meter. Running HAM heads and 9.0 CR. Runs like a bat out of hell! (IMG:style_emoticons/default/agree.gif) I just did this but with a 52mm modified GoWesty unit and removed the snorkel. I've got the new EMPI heads, but only went to 8.5:1 CR because I can't get 93 octane where I live. (IMG:style_emoticons/default/headbang.gif) Put a 123 disty in it at as well. It even pulls a bit in 5th gear now and doesn't want to stop. |
rfinegan L jet on 2L heads Sep 20 2025, 09:55 AM
914werke I used custom silicone connector hoses Sep 20 2025, 10:41 AM
rfinegan So you use the Djet runners on a Ljet plenum? SO i... Sep 20 2025, 10:51 AM
Dave_Darling You'd have to use the 2-liter runners. They... Sep 20 2025, 03:09 PM
914Sixer Take the 1.8 runners and drill 3rd center hole. Y... Sep 20 2025, 03:32 PM
JamesM
Take the 1.8 runners and drill 3rd center hole. ... Sep 20 2025, 07:14 PM
bdstone914 @[url=http://www.914world.com/bbs2/index.php?showu... Sep 25 2025, 06:53 AM
TRP Will you be running bigger injectors for the 2056?... Sep 20 2025, 06:45 PM
JamesM Find a 912e system :lol4: :lol4: :lol4:
Serio... Sep 20 2025, 07:13 PM
914werke So you use the (2.0L) D-jet runners on a Ljet ple... Sep 20 2025, 10:30 PM
GregAmy Genuine curiosity: why? Rebuiliding a 1.8L with 2L... Sep 21 2025, 06:26 AM
rfinegan @GregAmy , This will be and after market EFI crank... Sep 21 2025, 09:06 AM
rfinegan Thanks every one for the intake tips....no more sy... Sep 21 2025, 09:09 AM
914werke In my case it was a 2056 that I fitted a GoWesty T... Sep 21 2025, 11:46 AM
GregAmy Good info...so it appears the LJet is the preferre... Sep 21 2025, 03:30 PM
ClayPerrine I have run L-Jet on a 2.0 engine. The runners are... Sep 22 2025, 05:41 AM
JamesJ
I have run L-Jet on a 2.0 engine. The runners ar... Nov 21 2025, 12:57 PM
rfinegan Chat GTP 5
on throttle body size for 2056:
Short v... Sep 24 2025, 09:34 AM
JamesJ
I am running a 2056 with Ljet FI. Installed a 50... Nov 22 2025, 07:22 AM
Geezer914
[quote name='Geezer914' post='3225523' date='Sep ... Nov 23 2025, 09:39 AM
rbzymek
I am running a 2056 with Ljet FI. Installed a 50... Dec 5 2025, 08:58 AM
rfinegan Thanks all for the insights and advice as i move i... Sep 24 2025, 08:41 PM
914Sixer Yep, that was all read pointed out, my bad. Sep 25 2025, 06:57 AM
914werke Here you go :)
https://members.rennlist.com/demi... Nov 22 2025, 02:44 PM
JamesJ Thanks guys! Super helpful!
Rob, we'l... Nov 24 2025, 08:45 PM
rfinegan PROGRESS:
While I had the welder out for the O2 b... Dec 30 2025, 01:38 PM
Geezer914 When I installed the modified 50mm Vanagon throttl... Dec 31 2025, 09:37 AM
rfinegan Geezer914,
I plan on giving ^this^ a try once its ... Dec 31 2025, 09:54 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 02:02 AM |
