| tomeric914 |
Nov 23 2025, 07:58 PM
One Lap of America in a 914! ![]() ![]() ![]() Group: Members Posts: 1,319 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States
Been kicking around the idea of using a hydraulic release bearing (HRB) instead of a slave cylinder, stock fork and stock release bearing. You could argue that this route is more expensive, but it isn't that much more than a stock throwout bearing. Most modern stickshifts use a HRB. They're simpler, cut out a bunch of moving parts and generally give better feel.
Goal is for the adapter to bolt in with no modifications to the trans or bellhousing other than to remove the two 6mm studs that hold on the throwout bearing guide tube. One fitting runs through one of the two inspection holes at the top for a bleeder fitting. The other will be a stainless braided line out the fork hole with a little bracket to hold it in place. You'll also need to install a clutch master cylinder of your choosing up front. If this interests you, I'll probably make a bunch of adapters and offer them up here. Let me know what you think. Could also be in kit form with everything needed. For now, here's a teaser shot of the mock-up. |
| rfinegan |
Nov 25 2025, 07:15 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,189 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
looks like a GREAT solution ...follow this one for sure
tomeric914 Hydraulic Release Bearing for the 914 Transmission Nov 23 2025, 07:58 PM
sixnotfour Is that a GT3 Cup release bearing ?? OOPS... Tilt... Nov 24 2025, 08:25 PM
tomeric914
Is that a GT3 Cup release bearing ?? OOPS... Til... Nov 25 2025, 10:42 AM
Ninja I fought that fight 10 years ago on a big block co... Nov 25 2025, 01:01 PM
Cupomeat I'm interested in this solution. Sorry, I don... Nov 27 2025, 07:19 AM
tomeric914 I should have 5 of the adapters complete in the ne... Nov 27 2025, 09:51 AM
tomeric914 Prototype adapter installed and stack height verif... Dec 10 2025, 08:15 AM
sixnotfour :beer2: Dec 10 2025, 09:29 AM
tomeric914 Thanks to @tygaboy for his mentions of SendCutSe... Dec 26 2025, 10:37 AM
tygaboy Yep, SendCutSend really is a game-changer for us h... Dec 27 2025, 09:50 AM
Cupomeat :beer2: Dec 28 2025, 02:07 PM
tomeric914 More progress today. The fancy line bracket that ... Jan 4 2026, 09:32 PM
Cupomeat
More progress today. The fancy line bracket that... Jan 9 2026, 06:02 PM
sixnotfour Why not use the adjustable pedal stop ?? no shim ?... Jan 5 2026, 05:48 AM
tomeric914
Why not use the adjustable pedal stop ?? no shim ... Jan 5 2026, 09:25 PM
sixnotfour :beer2: Jan 5 2026, 05:52 AM
rfinegan wow, looking good...keep the updates coming Jan 5 2026, 09:40 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 01:11 AM |
