| Tking327 |
Nov 25 2025, 04:55 PM
Newbie ![]() Group: Members Posts: 25 Joined: 17-August 21 From: Denver,CO Member No.: 25,815 Region Association: Intermountain Region |
Hello, i tore down my 1970 1.7L to rebuild it and on cleaning the grease off the top of my crankcase, i saw the attached which made me nervous.
| Ninja |
Nov 25 2025, 07:36 PM
Member ![]() ![]() Group: Members Posts: 191 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
Normal.
Now, that surface you exposed, where the base of the jugs sit, is one of the more common areas to have machined flat. That surface sags with age alone. Sir Raby states it's almost never flat. You have to pull the head studs and find a machine shop that is willing to machine it flat. As it is lower than the case casting around it some machine shops don't have the equipment or knowledge to correctly mill that. |
Tking327 Casting Marks or Concerning cracks? Nov 25 2025, 04:55 PM
Jack Standz Typical feature of the case casting process. Nov 25 2025, 05:50 PM
mepstein Many threads on pelican about casting marks on eng... Nov 25 2025, 06:51 PM
Puebloswatcop
Hello, i tore down my 1970 1.7L to rebuild it and... Nov 25 2025, 06:58 PM
davep The easy test here is to determine if the marks ar... Nov 26 2025, 08:23 AM
Tking327 Super helpful these replies make sense. Thanks for... Nov 29 2025, 09:48 AM
Chad911sc Raby also says in his case comparison video that t... Nov 29 2025, 01:18 PM
davep That is wrong, only one casting was being produced... Nov 29 2025, 09:51 PM
Chad911sc I’m not sure how to link a video to this site, b... Dec 1 2025, 09:56 AM
Chad911sc @davep
You are absolutely correct!
After watc... Dec 1 2025, 10:04 AM
Chad911sc https://youtu.be/siPS_EBLxLY?si=UnHu1rJrBZiel1wi
T... Dec 1 2025, 10:27 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:44 AM |
