> high oil consumption, oil leaks across the piston rings
HLANG
post Nov 26 2025, 08:56 AM
Region Association: Germany
I just recently did a complete 2L engine overhaul and installed forged JE-Pistons with Biral Cylinder Liner kit 96 mm bore. The compression is fine, the engine runs well but I experience a consumption of 1 liter oil per 1.000 Km. After I checked the combustion chamber I found too much oil deposits on the spark plugs and the pistons. The ring gap of the piston rings is in tolerance so I wonder why there still passes so much oil from the crankcase into the combustion chamber.
JamesM
post Nov 26 2025, 08:59 PM
What does your crankcase venting situation look like?
- Lo-Fi Version Time is now: 1st April 2026 - 08:57 PM
