| trojanhorsepower |
Nov 26 2025, 03:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,031 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
All,
I am looking to change the oil pump as a way to up my oil pressure. I understand that this may well not help, but having a new oil pump around is OK. With that in mind, what are my options? I will pull the motor but hope to not split the case. Is this even possible? Which pump? Thanks Peter |
| Superhawk996 |
Nov 26 2025, 08:25 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Revisit my post #14 in your original thread.
You need to understand what is causing your issue before simply hoping for a better pump. Do you know what your current oil pump end clearance was? If you’re hell bent on buying a new Type 1 pump blindly, have the vendors measure the pump OD with a micrometer and get one that is the proper dimension. A couple thousands of an inch undersize is a huge deal and amounts to an internal leak that limits oil pressure - especially when hot and especially at idle. WRT to the question about splitting the case. You don’t have to split the case to swap an oil pump. |
| JamesM |
Nov 26 2025, 08:57 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,187 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Yeah, what?
Are you looking for just a "new" pump or a larger pump? New type 4 pumps do not exist and none of the available type 1 pumps fit properly and (assuming you have a stock type 4 pump) will most likely make your pressure issues worse due to the excessive pump body to case clearances. A few vendors sell o-ringed pumps to try and remedy the clearance issues but 1. it doesn't fully as orings can only seal the sides of the pump and does nothing about the output leaking back to the input side AND 2. forget about trying to install an o-ringed pump on an already assembled engine. ALSO A larger pump may move more volume, and it will take more HP do to so, it may also not gain you any pressure and is likely to overwhelm your oil cooler bypass (which may already be occurring anyways) and roast your oil. Probably should be asked what sort of oil pressure are you currently looking at? What sort of oil are you currently running? and When was the last time you pulled your engine tin and cleaned out all the crap? If you insist on a band aid approach: Step 1. if you dont already have one, get one of @chrisfoley Oil pressure relief valves. Chances are if your oil pump is worn your bypass valve/spring are worse Step 2: If after that you still insist on replacing your pump talk to Jorge at European Moterwerks. He sleeves and machines a 27mm type 3 pump to work on a type 4. Its expensive for a VW oil pump but its the only one available that I am aware of with proper port placement, proper clearances, and no O-rings to tear installing on an assembled case. Someone in Europe had made a run of billet type 4 pumps a while back but haven't seen them in a while, and between the cost of the custom billet part and how the import tariffs have been hitting car parts you would have to really hate your money to bring one in now. If you’re hell bent on buying a new Type 1 pump blindly, have the vendors measure the pump OD with a micrometer and get one that is the proper dimension. A couple thousands of an inch undersize is a huge deal and amounts to an internal leak that limits oil pressure - especially when hot and especially at idle. I don't believe they exist, if you find a reliable source please let me know. You would still want to port match them as well. |
| Superhawk996 |
Nov 26 2025, 11:34 PM
Someone in Europe had made a run of billet type 4 pumps a while back but haven't seen them in a while, and between the cost of the custom billet part and how the import tariffs have been hitting car parts you would have to really hate your money to bring one in now. @JamesM I bought one of those T4 CNC billet pumps back when they were available. 30mm gears so limited use cases It does have the proper OD and port match Idler shaft was not pinned or peened as I prefer to do with any T4 pump. ![]() ![]() With respect to sizing of T1 pumps it’s a tolerance game - there are some out there that are only 0.001” undersize so it’s a sorting game to find the best parts. I don’t have a reliable source for “good” parts. Your info on the modified T3 pump is interesting. Have never seen that service listed on the website but good to know. |
trojanhorsepower oil pump Nov 26 2025, 03:28 PM
trojanhorsepower @JamesM : Fresh build (20 years ago, but only inst... Nov 27 2025, 06:47 PM
Superhawk996
I understand that a different pump may not fix ... Nov 27 2025, 07:48 PM
Superhawk996
So new question if you are building a fresh 2056... Nov 27 2025, 07:55 PM
emerygt350 I have an old melling in mine. Works great but I k... Nov 28 2025, 07:31 AM
Superhawk996
I have an old melling in mine. Works great but I ... Nov 28 2025, 01:22 PM
trojanhorsepower OK thanks for the replies. I think I am getting t... Nov 28 2025, 09:03 AM
Superhawk996
@superhawk995 do you collect OEM T4 pumps and ju... Nov 28 2025, 12:47 PM
JamesM
OK thanks for the replies. I think I am getting ... Nov 28 2025, 01:01 PM
Superhawk996
A good fitting pump is a near interference fit w... Nov 28 2025, 01:13 PM
Superhawk996
OK thanks for the replies. I think I am getting ... Nov 28 2025, 01:03 PM
Jack Standz A couple options that might work for you?:
https:... Nov 28 2025, 09:34 AM
trojanhorsepower Man this is good stuff. Yes I understand that the... Nov 28 2025, 02:49 PM
Superhawk996
So I will work on getting a T4 pump with OD of 2... Nov 28 2025, 03:35 PM
Superhawk996 Some cases have bypass down on the lifter galley. ... Nov 28 2025, 03:32 PM
trojanhorsepower Pulled this pump from my donor motor. It's a ... Nov 29 2025, 02:41 PM
trojanhorsepower Read the Samba thread.....
Holy Crap. Not sure I ... Nov 29 2025, 03:23 PM
Superhawk996
Holy Crap. Not sure I... Nov 29 2025, 07:38 PM
Superhawk996 Post photos of your parts after clean up including... Nov 29 2025, 10:29 PM
trojanhorsepower Had a minute to clean the pump. Hear are some mor... Nov 30 2025, 12:04 PM
Superhawk996 That pump is looking pretty promising.
In the p... Nov 30 2025, 12:48 PM
Superhawk996 Also is there any noticeable feel or roughness dif... Nov 30 2025, 01:07 PM
trojanhorsepower OK I don't feel anything where the two circles... Nov 30 2025, 03:45 PM
trojanhorsepower The shaft looks much further in on this pump then ... Nov 30 2025, 03:46 PM
Superhawk996 Ok so let’s summarize:
That is a pretty decent... Nov 30 2025, 04:32 PM
Superhawk996 Here is an example of the T1 Shadek pump factory p... Nov 30 2025, 04:41 PM
trojanhorsepower OK, thanks for all the advice. I will swap the T1... Nov 30 2025, 06:05 PM
Superhawk996
Just out of curiosity is there anyone that sells... Nov 30 2025, 11:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st April 2026 - 10:53 PM |
