| DennisV |
Nov 27 2025, 09:31 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 884 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Has anyone had success repairing / replacing a broken stud in the front bumper top molding? One of the studs snapped off during disassembly, despite several soakings in Sea Foam. Best I can tell these are molded into the rubber. I can't think of a way to remove the remaining stud without making things worse. I could of course melt it out, but then I have no way to set a new stud. (IMG:style_emoticons/default/unsure.gif)
![]() I realize new ones are available for sale. This one is in quite good shape with the exception of that stud. Seems a shame to trash it. Especially when the new ones are hundreds of dollars. |
| IronHillRestorations |
Nov 27 2025, 09:52 AM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,926 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
You might try drilling it out and tapping it, then epoxy a stud. I’ve seen sheet metal screws used as well.
| DennisV |
Nov 27 2025, 10:08 AM
You might try drilling it out and tapping it, then epoxy a stud. I’ve seen sheet metal screws used as well. I didn't realize you could tap rubber. Is there an epoxy you've had good luck with? Most of my attempts to bond plastics with any amount of stress applied seem to fail. I see JB Weld has SuperWeld Extreme that claims it will work on rubber. |
DennisV Front Bumper Top Molding Stud Repair Nov 27 2025, 09:31 AM
FlacaProductions I successfully used JB Weld years ago to place a s... Nov 27 2025, 10:40 AM
Garland
I successfully used JB Weld years ago to place a ... Nov 27 2025, 12:30 PM
DennisV
I successfully used JB Weld years ago to place a ... Jan 11 2026, 09:02 PM
Artfrombama I suggest bonding the rubber to the bumper with pa... Nov 27 2025, 10:54 AM
914Sixer Stud was in a metal washer. Can be drilled and ta... Nov 27 2025, 12:58 PM
914rrr It's been several years, but IIRC, I was able ... Dec 17 2025, 05:26 PM
rgalla9146
It's been several years, but IIRC, I was able... Dec 17 2025, 08:24 PM
FlacaProductions Excellent- JB Weld getting some love on here of la... Jan 12 2026, 09:21 AM
gereed75 Looks like you got it
I used 3M Marine 5200 to re... Jan 12 2026, 01:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st April 2026 - 09:46 PM |
