| DennisV |
Nov 27 2025, 09:31 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 884 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Has anyone had success repairing / replacing a broken stud in the front bumper top molding? One of the studs snapped off during disassembly, despite several soakings in Sea Foam. Best I can tell these are molded into the rubber. I can't think of a way to remove the remaining stud without making things worse. I could of course melt it out, but then I have no way to set a new stud. (IMG:style_emoticons/default/unsure.gif)
![]() I realize new ones are available for sale. This one is in quite good shape with the exception of that stud. Seems a shame to trash it. Especially when the new ones are hundreds of dollars. |
| FlacaProductions |
Nov 27 2025, 10:40 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,176 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
I successfully used JB Weld years ago to place a stud that had pulled out of a rear lower spoiler on a 944 Turbo - very similar material to the 914 bumper tops. I'd try drilling it out, fill the hole with JB and then insert a new stud and let it set up. Just have to pay attention to make sure you have correct alignment and depth.
| Garland |
Nov 27 2025, 12:30 PM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,430 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
I successfully used JB Weld years ago to place a stud that had pulled out of a rear lower spoiler on a 944 Turbo - very similar material to the 914 bumper tops. I'd try drilling it out, fill the hole with JB and then insert a new stud and let it set up. Just have to pay attention to make sure you have correct alignment and depth. (IMG:style_emoticons/default/agree.gif) Exactly! J&B |
DennisV Front Bumper Top Molding Stud Repair Nov 27 2025, 09:31 AM
IronHillRestorations You might try drilling it out and tapping it, then... Nov 27 2025, 09:52 AM
DennisV
You might try drilling it out and tapping it, the... Nov 27 2025, 10:08 AM
DennisV
I successfully used JB Weld years ago to place a ... Jan 11 2026, 09:02 PM
Artfrombama I suggest bonding the rubber to the bumper with pa... Nov 27 2025, 10:54 AM
914Sixer Stud was in a metal washer. Can be drilled and ta... Nov 27 2025, 12:58 PM
914rrr It's been several years, but IIRC, I was able ... Dec 17 2025, 05:26 PM
rgalla9146
It's been several years, but IIRC, I was able... Dec 17 2025, 08:24 PM
FlacaProductions Excellent- JB Weld getting some love on here of la... Jan 12 2026, 09:21 AM
gereed75 Looks like you got it
I used 3M Marine 5200 to re... Jan 12 2026, 01:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st April 2026 - 09:46 PM |
