> high oil consumption, oil leaks across the piston rings
HLANG
post Nov 26 2025, 08:56 AM
Region Association: Germany
I just recently did a complete 2L engine overhaul and installed forged JE-Pistons with Biral Cylinder Liner kit 96 mm bore. The compression is fine, the engine runs well but I experience a consumption of 1 liter oil per 1.000 Km. After I checked the combustion chamber I found too much oil deposits on the spark plugs and the pistons. The ring gap of the piston rings is in tolerance so I wonder why there still passes so much oil from the crankcase into the combustion chamber.
HLANG
post Nov 28 2025, 07:29 AM
Thank you guys for your feedback. It seems like the oil consumption is in spec but still a little high. As this have been the first 1.000 Km for the new engine, I give the whole thing a little time to settle in while monitoring carefully.
By the way: it`s a first hand 1973 Porsche 914 that I have overhauled over the last years. I couldn`t do it without having such a good forum and many enthusiasts like you.
- Lo-Fi Version Time is now: 1st April 2026 - 08:58 PM
