| trojanhorsepower |
Nov 26 2025, 03:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,031 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
All,
I am looking to change the oil pump as a way to up my oil pressure. I understand that this may well not help, but having a new oil pump around is OK. With that in mind, what are my options? I will pull the motor but hope to not split the case. Is this even possible? Which pump? Thanks Peter |
| Jack Standz |
Nov 28 2025, 09:34 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 743 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
A couple options that might work for you?:
https://germansupply.com/type-4-oil-pump-billet.html https://www.cbperformance.com/product-p/1829.htm Personally, my next type iv motor will have a "blueprinted" o-ringed and modified type I pump from Gene Berg. And oil pressure will be carefully monitored both during initial start-up and use. That's with a gauge, not a light. (IMG:style_emoticons/default/smile.gif) Why? Because already have it and it's dimensions are within specifications. And, if it's not working right, it's replaceable. Edit: And the billet pump is listed at $412 (plus tariffs-taxes, shipping, etc.). But, also just noticed it's currently is out-of-stock. Might not ever be back in-stock? |
trojanhorsepower oil pump Nov 26 2025, 03:28 PM
Superhawk996 Revisit my post #14 in your original thread.
Yo... Nov 26 2025, 08:25 PM
JamesM Yeah, what?
Are you looking for just a "new... Nov 26 2025, 08:57 PM
Superhawk996
Someone in Europe had made a run of billet type... Nov 26 2025, 11:34 PM
trojanhorsepower @JamesM : Fresh build (20 years ago, but only inst... Nov 27 2025, 06:47 PM
Superhawk996
I understand that a different pump may not fix ... Nov 27 2025, 07:48 PM
Superhawk996
So new question if you are building a fresh 2056... Nov 27 2025, 07:55 PM
emerygt350 I have an old melling in mine. Works great but I k... Nov 28 2025, 07:31 AM
Superhawk996
I have an old melling in mine. Works great but I ... Nov 28 2025, 01:22 PM
trojanhorsepower OK thanks for the replies. I think I am getting t... Nov 28 2025, 09:03 AM
Superhawk996
@superhawk995 do you collect OEM T4 pumps and ju... Nov 28 2025, 12:47 PM
JamesM
OK thanks for the replies. I think I am getting ... Nov 28 2025, 01:01 PM
Superhawk996
A good fitting pump is a near interference fit w... Nov 28 2025, 01:13 PM
Superhawk996
OK thanks for the replies. I think I am getting ... Nov 28 2025, 01:03 PM
trojanhorsepower Man this is good stuff. Yes I understand that the... Nov 28 2025, 02:49 PM
Superhawk996
So I will work on getting a T4 pump with OD of 2... Nov 28 2025, 03:35 PM
Superhawk996 Some cases have bypass down on the lifter galley. ... Nov 28 2025, 03:32 PM
trojanhorsepower Pulled this pump from my donor motor. It's a ... Nov 29 2025, 02:41 PM
trojanhorsepower Read the Samba thread.....
Holy Crap. Not sure I ... Nov 29 2025, 03:23 PM
Superhawk996
Holy Crap. Not sure I... Nov 29 2025, 07:38 PM
Superhawk996 Post photos of your parts after clean up including... Nov 29 2025, 10:29 PM
trojanhorsepower Had a minute to clean the pump. Hear are some mor... Nov 30 2025, 12:04 PM
Superhawk996 That pump is looking pretty promising.
In the p... Nov 30 2025, 12:48 PM
Superhawk996 Also is there any noticeable feel or roughness dif... Nov 30 2025, 01:07 PM
trojanhorsepower OK I don't feel anything where the two circles... Nov 30 2025, 03:45 PM
trojanhorsepower The shaft looks much further in on this pump then ... Nov 30 2025, 03:46 PM
Superhawk996 Ok so let’s summarize:
That is a pretty decent... Nov 30 2025, 04:32 PM
Superhawk996 Here is an example of the T1 Shadek pump factory p... Nov 30 2025, 04:41 PM
trojanhorsepower OK, thanks for all the advice. I will swap the T1... Nov 30 2025, 06:05 PM
Superhawk996
Just out of curiosity is there anyone that sells... Nov 30 2025, 11:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st April 2026 - 09:29 PM |
