| Ebradley |
Nov 28 2025, 10:56 AM
Member ![]() ![]() Group: Members Posts: 60 Joined: 16-April 20 From: California Member No.: 24,142 Region Association: Southern California |
I have a 74(2.0) that has issues when it’s hot outside. I’ll drive it and then it won’t start or stalls when stopped. It tries to start crescendo like ramping up faster and faster and when it does I have to keep the RPMs going or it will die. I’ve never had a problem when the weather is not hot. Until today. I drove it this morning and it’s cold outside, and I’ve encountered the same issue. Any ideas? Vapor lock? Not even sure. Thanks. |
| wonkipop |
Nov 28 2025, 01:48 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,252 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
is it starting ok after being left over night?
and then being difficult after you have run it for a while? this can seem like a hot start v cold start scenario but not due to vapor lock. rather a blocked fuel line somewhere. either collapsed line or blocked filter. if so i'd check out what @JamesM is hinting at. if the fuel pump is in original location check the plastic cube fuel filter just before the fuel pump. under the car near the pump. could be clogged. good first port of call. agree with @JamesM about installing a full flow high pressure filter after the pump. check the eletrical connection to the pump. make sure its not corroded or loose. |
Ebradley Any suggestions? Nov 28 2025, 10:56 AM
chmillman
I have a 74(2.0) that has issues when it’s hot ... Nov 28 2025, 11:42 AM
Ebradley All original d-jet. Car has little over a 100k mil... Nov 28 2025, 11:53 AM
FlacaProductions collapsing/clogged fuel line or filter? Nov 28 2025, 12:25 PM
JamesM Need more information to properly diagnose but at ... Nov 28 2025, 01:12 PM
Ebradley I’ll check that. Thanks for the suggestions Nov 28 2025, 02:15 PM
Dlee6205 Since you're thinking it's fuel related, I... Nov 28 2025, 02:33 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th November 2025 - 03:09 PM |
