> oil pump, which one
trojanhorsepower
post Nov 26 2025, 03:28 PM
All,
I am looking to change the oil pump as a way to up my oil pressure. I understand that this may well not help, but having a new oil pump around is OK.
With that in mind, what are my options? I will pull the motor but hope to not split the case. Is this even possible? Which pump?
Thanks
Peter
trojanhorsepower
post Nov 28 2025, 02:49 PM
Man this is good stuff. Yes I understand that the pump is just one part of the system, I did tangerine bypass and it doubled my cold oil pressure (~ 35 AT cold idle to ~65 at cold idle). I think there is a bypass for the oil filter, but where is the 3rd bypass?
I like the idea of checking everything, but would like to have a pump ready to go in if I find something out of spec. So I will work on getting a T4 pump with OD of 2.757" then pull the motor and hope everything goes well.
trojanhorsepower   oil pump   Nov 26 2025, 03:28 PM
Superhawk996   Revisit my post #14 in your original thread. Yo...   Nov 26 2025, 08:25 PM
JamesM   Yeah, what? Are you looking for just a "new...   Nov 26 2025, 08:57 PM
Superhawk996   Someone in Europe had made a run of billet type...   Nov 26 2025, 11:34 PM
trojanhorsepower   @JamesM : Fresh build (20 years ago, but only inst...   Nov 27 2025, 06:47 PM
Superhawk996   I understand that a different pump may not fix ...   Nov 27 2025, 07:48 PM
Superhawk996   So new question if you are building a fresh 2056...   Nov 27 2025, 07:55 PM
emerygt350   I have an old melling in mine. Works great but I k...   Nov 28 2025, 07:31 AM
Superhawk996   I have an old melling in mine. Works great but I ...   Nov 28 2025, 01:22 PM
trojanhorsepower   OK thanks for the replies. I think I am getting t...   Nov 28 2025, 09:03 AM
Superhawk996   @superhawk995 do you collect OEM T4 pumps and ju...   Nov 28 2025, 12:47 PM
JamesM   OK thanks for the replies. I think I am getting ...   Nov 28 2025, 01:01 PM
Superhawk996   A good fitting pump is a near interference fit w...   Nov 28 2025, 01:13 PM
Superhawk996   OK thanks for the replies. I think I am getting ...   Nov 28 2025, 01:03 PM
Jack Standz   A couple options that might work for you?: https:...   Nov 28 2025, 09:34 AM
trojanhorsepower   Man this is good stuff. Yes I understand that the...   Nov 28 2025, 02:49 PM
Superhawk996   So I will work on getting a T4 pump with OD of 2...   Nov 28 2025, 03:35 PM
Superhawk996   Some cases have bypass down on the lifter galley. ...   Nov 28 2025, 03:32 PM
trojanhorsepower   Pulled this pump from my donor motor. It's a ...   Nov 29 2025, 02:41 PM
trojanhorsepower   Read the Samba thread..... Holy Crap. Not sure I ...   Nov 29 2025, 03:23 PM
Superhawk996   Read the Samba thread..... Holy Crap. Not sure I...   Nov 29 2025, 07:38 PM
Superhawk996   Post photos of your parts after clean up including...   Nov 29 2025, 10:29 PM
trojanhorsepower   Had a minute to clean the pump. Hear are some mor...   Nov 30 2025, 12:04 PM
Superhawk996   That pump is looking pretty promising. In the p...   Nov 30 2025, 12:48 PM
Superhawk996   Also is there any noticeable feel or roughness dif...   Nov 30 2025, 01:07 PM
trojanhorsepower   OK I don't feel anything where the two circles...   Nov 30 2025, 03:45 PM
trojanhorsepower   The shaft looks much further in on this pump then ...   Nov 30 2025, 03:46 PM
Superhawk996   Ok so let’s summarize: That is a pretty decent...   Nov 30 2025, 04:32 PM
Superhawk996   Here is an example of the T1 Shadek pump factory p...   Nov 30 2025, 04:41 PM
trojanhorsepower   OK, thanks for all the advice. I will swap the T1...   Nov 30 2025, 06:05 PM
Superhawk996   Just out of curiosity is there anyone that sells...   Nov 30 2025, 11:16 PM
- Lo-Fi Version Time is now: 1st April 2026 - 09:29 PM
