| Jim C |
Jul 26 2024, 08:25 AM
Member ![]() ![]() Group: Members Posts: 206 Joined: 11-July 19 From: Pennsylvania Member No.: 23,294 Region Association: MidAtlantic Region
When I received a replacement wiper switch there was a small brass tab held by a small nut and bolt in the hole where the upper left screw holding the switch to the steering column would go. Since the switch I removed did not have such a tab and since the tab blocked a mounting hole I removed it. The switch without the tab did not function properly and also seemed to adversely impact the function of the turn signal switch. Since then I have read that the brass tab is needed for proper grounding. Here's my question: How in the heck do you mount the switch in the steering wheel without having the little brass tab repeatedly fall off. What should have been a quick easy job has become a never-ending saga!
| 914Sixer |
Nov 28 2025, 05:26 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,348 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Jim,
Some do, some don't. I included ground tab on switch I sent. |
| jim_hoyland |
Nov 28 2025, 05:55 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,953 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Jim, Some do, some don't. I included ground tab on switch I sent. Use it, looks like you taped it in place. Attached thumbnail(s) |
Jim C 1976 Windshield Wiper Switch Replacement Jul 26 2024, 08:25 AM
914Sixer Jim,
The nut was there so I did not loose tab. Ta... Jul 26 2024, 09:25 AM
Jim C
Jim,
The nut was there so I did not loose tab. T... Jul 26 2024, 09:34 AM
jim_hoyland Do all the wiper switches have the grounding tab ?... Nov 28 2025, 04:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th November 2025 - 04:25 AM |
