| trojanhorsepower |
Nov 26 2025, 03:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,031 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
All,
I am looking to change the oil pump as a way to up my oil pressure. I understand that this may well not help, but having a new oil pump around is OK. With that in mind, what are my options? I will pull the motor but hope to not split the case. Is this even possible? Which pump? Thanks Peter |
| trojanhorsepower |
Nov 29 2025, 03:23 PM
Read the Samba thread.....
Holy Crap. Not sure I can do that. Of all tools he mentions I have a magnetic dial, the punch and hammer and that's about it. |
| Superhawk996 |
Nov 29 2025, 07:38 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Read the Samba thread..... Holy Crap. Not sure I can do that. Of all tools he mentions I have a magnetic dial, the punch and hammer and that's about it. That thread is extensive but good on you for self assessing that you can’t do it all. That post really lays out the ideal approach of measuring gear lash, lapping in end clearance to perfection, etc. Here’s the practical approach. See photos Clean up that pump. Inspect gears for pitting. Subjectively feel the backlash, should barely be perceptible. Inspect housing for any scoring. Unless the engine grenades and pumped shrapnel or was seriously abused, most oil pumps are suitable for reuse. Oil pumps by their nature are oil immersed and over lubricated so actual unusable wear is pretty rare. Gear pitting - bad (scrap) ![]() Pump body - near perfect ![]() Pump body badly scored and damaged - scrap ![]() |
trojanhorsepower oil pump Nov 26 2025, 03:28 PM
Superhawk996 Revisit my post #14 in your original thread.
Yo... Nov 26 2025, 08:25 PM
JamesM Yeah, what?
Are you looking for just a "new... Nov 26 2025, 08:57 PM
Superhawk996
Someone in Europe had made a run of billet type... Nov 26 2025, 11:34 PM
trojanhorsepower @JamesM : Fresh build (20 years ago, but only inst... Nov 27 2025, 06:47 PM
Superhawk996
I understand that a different pump may not fix ... Nov 27 2025, 07:48 PM
Superhawk996
So new question if you are building a fresh 2056... Nov 27 2025, 07:55 PM
emerygt350 I have an old melling in mine. Works great but I k... Nov 28 2025, 07:31 AM
Superhawk996
I have an old melling in mine. Works great but I ... Nov 28 2025, 01:22 PM
trojanhorsepower OK thanks for the replies. I think I am getting t... Nov 28 2025, 09:03 AM
Superhawk996
@superhawk995 do you collect OEM T4 pumps and ju... Nov 28 2025, 12:47 PM
JamesM
OK thanks for the replies. I think I am getting ... Nov 28 2025, 01:01 PM
Superhawk996
A good fitting pump is a near interference fit w... Nov 28 2025, 01:13 PM
Superhawk996
OK thanks for the replies. I think I am getting ... Nov 28 2025, 01:03 PM
Jack Standz A couple options that might work for you?:
https:... Nov 28 2025, 09:34 AM
trojanhorsepower Man this is good stuff. Yes I understand that the... Nov 28 2025, 02:49 PM
Superhawk996
So I will work on getting a T4 pump with OD of 2... Nov 28 2025, 03:35 PM
Superhawk996 Some cases have bypass down on the lifter galley. ... Nov 28 2025, 03:32 PM
trojanhorsepower Pulled this pump from my donor motor. It's a ... Nov 29 2025, 02:41 PM
Superhawk996 Post photos of your parts after clean up including... Nov 29 2025, 10:29 PM
trojanhorsepower Had a minute to clean the pump. Hear are some mor... Nov 30 2025, 12:04 PM
Superhawk996 That pump is looking pretty promising.
In the p... Nov 30 2025, 12:48 PM
Superhawk996 Also is there any noticeable feel or roughness dif... Nov 30 2025, 01:07 PM
trojanhorsepower OK I don't feel anything where the two circles... Nov 30 2025, 03:45 PM
trojanhorsepower The shaft looks much further in on this pump then ... Nov 30 2025, 03:46 PM
Superhawk996 Ok so let’s summarize:
That is a pretty decent... Nov 30 2025, 04:32 PM
Superhawk996 Here is an example of the T1 Shadek pump factory p... Nov 30 2025, 04:41 PM
trojanhorsepower OK, thanks for all the advice. I will swap the T1... Nov 30 2025, 06:05 PM
Superhawk996
Just out of curiosity is there anyone that sells... Nov 30 2025, 11:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st April 2026 - 09:29 PM |
