> oil pump, which one
trojanhorsepower
post Nov 26 2025, 03:28 PM
All,
I am looking to change the oil pump as a way to up my oil pressure. I understand that this may well not help, but having a new oil pump around is OK.
With that in mind, what are my options? I will pull the motor but hope to not split the case. Is this even possible? Which pump?
Thanks
Peter
trojanhorsepower
post Nov 30 2025, 06:05 PM
OK, thanks for all the advice. I will swap the T1 for this T4 later this year and report back.
Just out of curiosity is there anyone that sells refurbished (like the Samba) oil pumps?
trojanhorsepower   oil pump   Nov 26 2025, 03:28 PM
Superhawk996   Revisit my post #14 in your original thread. Yo...   Nov 26 2025, 08:25 PM
JamesM   Yeah, what? Are you looking for just a "new...   Nov 26 2025, 08:57 PM
Superhawk996   Someone in Europe had made a run of billet type...   Nov 26 2025, 11:34 PM
trojanhorsepower   @JamesM : Fresh build (20 years ago, but only inst...   Nov 27 2025, 06:47 PM
Superhawk996   I understand that a different pump may not fix ...   Nov 27 2025, 07:48 PM
Superhawk996   So new question if you are building a fresh 2056...   Nov 27 2025, 07:55 PM
emerygt350   I have an old melling in mine. Works great but I k...   Nov 28 2025, 07:31 AM
Superhawk996   I have an old melling in mine. Works great but I ...   Nov 28 2025, 01:22 PM
trojanhorsepower   OK thanks for the replies. I think I am getting t...   Nov 28 2025, 09:03 AM
Superhawk996   @superhawk995 do you collect OEM T4 pumps and ju...   Nov 28 2025, 12:47 PM
JamesM   OK thanks for the replies. I think I am getting ...   Nov 28 2025, 01:01 PM
Superhawk996   A good fitting pump is a near interference fit w...   Nov 28 2025, 01:13 PM
Superhawk996   OK thanks for the replies. I think I am getting ...   Nov 28 2025, 01:03 PM
Jack Standz   A couple options that might work for you?: https:...   Nov 28 2025, 09:34 AM
trojanhorsepower   Man this is good stuff. Yes I understand that the...   Nov 28 2025, 02:49 PM
Superhawk996   So I will work on getting a T4 pump with OD of 2...   Nov 28 2025, 03:35 PM
Superhawk996   Some cases have bypass down on the lifter galley. ...   Nov 28 2025, 03:32 PM
trojanhorsepower   Pulled this pump from my donor motor. It's a ...   Nov 29 2025, 02:41 PM
trojanhorsepower   Read the Samba thread..... Holy Crap. Not sure I ...   Nov 29 2025, 03:23 PM
Superhawk996   Read the Samba thread..... Holy Crap. Not sure I...   Nov 29 2025, 07:38 PM
Superhawk996   Post photos of your parts after clean up including...   Nov 29 2025, 10:29 PM
trojanhorsepower   Had a minute to clean the pump. Hear are some mor...   Nov 30 2025, 12:04 PM
Superhawk996   That pump is looking pretty promising. In the p...   Nov 30 2025, 12:48 PM
Superhawk996   Also is there any noticeable feel or roughness dif...   Nov 30 2025, 01:07 PM
trojanhorsepower   OK I don't feel anything where the two circles...   Nov 30 2025, 03:45 PM
trojanhorsepower   The shaft looks much further in on this pump then ...   Nov 30 2025, 03:46 PM
Superhawk996   Ok so let’s summarize: That is a pretty decent...   Nov 30 2025, 04:32 PM
Superhawk996   Here is an example of the T1 Shadek pump factory p...   Nov 30 2025, 04:41 PM
trojanhorsepower   OK, thanks for all the advice. I will swap the T1...   Nov 30 2025, 06:05 PM
Superhawk996   Just out of curiosity is there anyone that sells...   Nov 30 2025, 11:16 PM
- Lo-Fi Version Time is now: 1st April 2026 - 09:27 PM
