| trojanhorsepower |
Nov 26 2025, 03:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,031 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
All,
I am looking to change the oil pump as a way to up my oil pressure. I understand that this may well not help, but having a new oil pump around is OK. With that in mind, what are my options? I will pull the motor but hope to not split the case. Is this even possible? Which pump? Thanks Peter |
| trojanhorsepower |
Nov 30 2025, 06:05 PM
OK, thanks for all the advice. I will swap the T1 for this T4 later this year and report back.
Just out of curiosity is there anyone that sells refurbished (like the Samba) oil pumps? |
| Superhawk996 |
Nov 30 2025, 11:16 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Just out of curiosity is there anyone that sells refurbished (like the Samba) oil pumps? Not that I’m aware of. The problem is the labor to do the work makes the refurbished T4 pump cost uncompetitive to just buying a T1 pump. I was away from hardcore 914 work from about 1999-2018. Somewhere in there, it appears everyone started using T1 pumps because they are cheap and T4 pumps became NLA. Maybe at one point the T1 pumps fit better? But based on the Raby post of him doing his own billet CNC pumps I’m inferring that they were always somewhat of a problem for him to get properly sized T1 pumps too. When I bought that billet CNC 30mm T4 pump that was around $300. Gives you an idea of why so many are highly motivated to use the modified T1 pumps regardless of the warts. Using a $300 pump on a $25k engine build makes sense. But to reiterate, oil pumps rarely fail unless abused by 1) Overheating 2) Running out of oil and running them dry 3) Engine damage occurs & shrapnel gets ingested and score the pump body, end plate, and gears. 4) Pump / engine sat outside exposed to weather, acidic oil, water/rust pitting damage, etc. Many could simply reuse their old T4 pump but they have been misled into thinking the new $50 or $60 modified Shadek is always better than a used T4 pump which isn’t always the case. Again: may have made sense at some point but given current T1 pump size issues I personally don’t think this still applies. A great example of this ability to reuse oil pumps shows up in the 911 world where it’s a whole lot more common to reuse oil pumps and oil coolers unless something catastrophic has occurred. The difference there being a new 4 rib oil pump will set you back $1000 ish. Not an apples to apples comparison as the 911 pump is way more complicated than the T4 pump but you get the point of why reuse is so much more common. |
trojanhorsepower oil pump Nov 26 2025, 03:28 PM
Superhawk996 Revisit my post #14 in your original thread.
Yo... Nov 26 2025, 08:25 PM
JamesM Yeah, what?
Are you looking for just a "new... Nov 26 2025, 08:57 PM
Superhawk996
Someone in Europe had made a run of billet type... Nov 26 2025, 11:34 PM
trojanhorsepower @JamesM : Fresh build (20 years ago, but only inst... Nov 27 2025, 06:47 PM
Superhawk996
I understand that a different pump may not fix ... Nov 27 2025, 07:48 PM
Superhawk996
So new question if you are building a fresh 2056... Nov 27 2025, 07:55 PM
emerygt350 I have an old melling in mine. Works great but I k... Nov 28 2025, 07:31 AM
Superhawk996
I have an old melling in mine. Works great but I ... Nov 28 2025, 01:22 PM
trojanhorsepower OK thanks for the replies. I think I am getting t... Nov 28 2025, 09:03 AM
Superhawk996
@superhawk995 do you collect OEM T4 pumps and ju... Nov 28 2025, 12:47 PM
JamesM
OK thanks for the replies. I think I am getting ... Nov 28 2025, 01:01 PM
Superhawk996
A good fitting pump is a near interference fit w... Nov 28 2025, 01:13 PM
Superhawk996
OK thanks for the replies. I think I am getting ... Nov 28 2025, 01:03 PM
Jack Standz A couple options that might work for you?:
https:... Nov 28 2025, 09:34 AM
trojanhorsepower Man this is good stuff. Yes I understand that the... Nov 28 2025, 02:49 PM
Superhawk996
So I will work on getting a T4 pump with OD of 2... Nov 28 2025, 03:35 PM
Superhawk996 Some cases have bypass down on the lifter galley. ... Nov 28 2025, 03:32 PM
trojanhorsepower Pulled this pump from my donor motor. It's a ... Nov 29 2025, 02:41 PM
trojanhorsepower Read the Samba thread.....
Holy Crap. Not sure I ... Nov 29 2025, 03:23 PM
Superhawk996
Holy Crap. Not sure I... Nov 29 2025, 07:38 PM
Superhawk996 Post photos of your parts after clean up including... Nov 29 2025, 10:29 PM
trojanhorsepower Had a minute to clean the pump. Hear are some mor... Nov 30 2025, 12:04 PM
Superhawk996 That pump is looking pretty promising.
In the p... Nov 30 2025, 12:48 PM
Superhawk996 Also is there any noticeable feel or roughness dif... Nov 30 2025, 01:07 PM
trojanhorsepower OK I don't feel anything where the two circles... Nov 30 2025, 03:45 PM
trojanhorsepower The shaft looks much further in on this pump then ... Nov 30 2025, 03:46 PM
Superhawk996 Ok so let’s summarize:
That is a pretty decent... Nov 30 2025, 04:32 PM
Superhawk996 Here is an example of the T1 Shadek pump factory p... Nov 30 2025, 04:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st April 2026 - 09:29 PM |
