> Center console clocks
DC_neun_vierzehn
post Nov 22 2025, 05:00 PM
Does anybody have a working clock in their center console? It seems like everyone clock has died.
I bought a reproduction clock from Auto Atlanta and it broke in less than a year. Complete waste of money.
Has anybody sent their clock to be rebuilt and if so how did it work out?
I think I read somewhere that only 914 clocks with a date stamp of 75 or 76 can be rebuilt as the internals changed?
DC_neun_vierzehn
post Dec 1 2025, 11:20 AM
So while I had my busted clock out I decided to install a new console wiring harness (fabricated by @Puebloswatcop ) because mine looked rather brittle. Great craftsmanship. It was a simple swap out - my car still had the original main wiring harness plugs in the tunnel area where the console wiring harness connects.
I have a working VDO quartz clock from an 80s VW (I believe), that I was going to use until I find a proper 914 clock (or possibly replace with an oil pressure gauge eventually). When I put power on the 80s VW VDO clock directly from the battery it works. But when I plug the clock into the console gauge wiring in the it does not work.
So I broke out the multi-meter. When I test the console harness clock power and ground wires with a multi-meter, it's not reading any power (with the ignition key "on" or "off"). For the clock it should be powered "on" regardless of the key's position. The other two gauges (temp and volt) work as they should (power only when the ignition is "on") and test perfectly with the multimeter.
Next I tested the clock power wire (black) from the main harness where it plugs into the console gauge harness above the tunnel (under the bottom of the console). It was hard to get the multimeter on the metal connectors in those original plastic connection plugs, but I think I was able to make contact to test. The multimeter showed no power on the main harness black power wire and brown ground).
I thought I would consult with the group ...
What is my next move?
Is there another place where I can test it for power further up stream?
Is I possible the metal connectors inside the plastic housing are corroded or wiring broken? Should I break the plastic housing open to inspect (knowing I will then need to put two new female connectors on using shrink wrap over each since of those 2 connections since I will no longer have the plastic housing)?
DC_neun_vierzehn   Center console clocks   Nov 22 2025, 05:00 PM
Shivers   This had some info. http://www.914world.com/bbs2...   Nov 22 2025, 05:26 PM
DC_neun_vierzehn   This had some info. http://www.914world.com/bbs...   Nov 30 2025, 11:01 AM
chmillman   Does anybody have a working clock in their center...   Nov 23 2025, 02:03 AM
StarBear   Does anybody have a working clock in their cente...   Dec 1 2025, 04:29 PM
914Sixer   I have 2 clocks with NEW movements. I was going t...   Nov 23 2025, 07:00 AM
FlacaProductions   I have one that is good to go from a NH Speedo res...   Nov 23 2025, 10:49 AM
930cabman   Guessin I'm lucky. I have 3 and they all work ...   Nov 30 2025, 01:25 PM
DC_neun_vierzehn   Guessin I'm lucky. I have 3 and they all work...   Nov 30 2025, 01:54 PM
930cabman   Guessin I'm lucky. I have 3 and they all wor...   Nov 30 2025, 07:52 PM
didenpx   Volvo had small diameter clocks made by vdo in the...   Nov 30 2025, 03:14 PM
DC_neun_vierzehn   So while I had my busted clock out I decided to in...   Dec 1 2025, 11:20 AM
rfinegan   My clock is correct 2 times a day!   Dec 1 2025, 01:50 PM
DC_neun_vierzehn   I'm really tempted to crack this thing open (s...   Dec 1 2025, 03:35 PM
fiacra   I'm really tempted to crack this thing open (...   Dec 1 2025, 04:56 PM
Puebloswatcop   I'm really tempted to crack this thing open (...   Dec 1 2025, 09:30 PM
DC_neun_vierzehn   I'm really tempted to crack this thing open ...   Dec 2 2025, 07:01 AM
DC_neun_vierzehn   [quote name='DC_neun_vierzehn' post='3235085' da...   Dec 4 2025, 10:15 AM
fiacra   @DC_neun_vierzehn I have this one in my parts st...   Dec 1 2025, 05:36 PM
DC_neun_vierzehn   @fiacra Good tip on that probe kit. I will give ...   Dec 1 2025, 07:21 PM
Puebloswatcop   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Dec 1 2025, 08:30 PM
DC_neun_vierzehn   [quote name='DC_neun_vierzehn' post='3235132' dat...   Dec 2 2025, 06:59 AM
914Sixer   This Audi/VW clock is a direct replacement for the...   Dec 1 2025, 08:17 PM
914rrr   Q: if the clock mechanism is still working, would ...   Dec 2 2025, 07:38 AM
Puebloswatcop   Q: if the clock mechanism is still working, would...   Dec 2 2025, 08:13 AM
930cabman   Q: if the clock mechanism is still working, woul...   Dec 15 2025, 02:58 PM
chmillman   I measured this way back when I had a similar issu...   Dec 2 2025, 08:06 AM
DC_neun_vierzehn   @[url=http://www.914world.com/bbs2/index.php?showu...   Dec 15 2025, 12:44 PM
DC_neun_vierzehn   I was finally able to cobble together a working an...   Jan 1 2026, 02:59 PM
- Lo-Fi Version Time is now: 14th March 2026 - 01:47 AM
