> Fuel Line Update, Winter Project
SteveL
post Nov 30 2025, 05:54 PM
74 1.8 - I previously replaced the 3-port fuel pump with a 2-port pump, mounted to the engine firewall. I have since sent the 3-port pump in for rebuild and have it back.
I have been fighting fueling issues for a long time - fuel pressure drops to 0, engine bogs down/dies. Wait a couple minutes and starts again. I'm down to assuming that there must be a fuel line kink, or a fuel line collapsing somewhere.
SO - winter project - All New Fuel Lines.
I need some help from the collective brain trust please. Do I:
1: Move fuel pump to frunk by spare tire, stainless lines thru tunnel, new rubber lines everywhere else
2: Leave fuel pump on engine firewall, stainless lines thru tunnel, new rubber lines everywhere else
3: Revert back to stock setup with 3-port pump, stainless lines thru tunnel, new rubber lines everywhere else
To complete the above - what do I need to order for the stainless line update, and who is the best to order from? Are they all made by the same person, or are there differences? (and do I need the reducing stainless line from CFR?)
Thank you in advance for all the help - Steve
jhynesrockmtn
post Dec 1 2025, 04:18 PM
I would vote for 1. In my 1970, I've been running a 2 port for a few years. I used a mounting kit from Tangerine Racing that placed it near the steering rack. I also used his lines. He's really good to work with. I put it near the rack because some PO had mounted a pump to the rack itself with some zip ties so the wiring was there already. I don't think the 2 port is your issue unless it is old and not functioning.
If your fuel tank isn't in really good shape, sediment can settle when parked, then get kicked up when moving and clog the fuel sock in the tank. I had this issue and it would start fine, then once moving die.
- Lo-Fi Version Time is now: 3rd March 2026 - 06:25 AM
