| chmillman |
Dec 3 2025, 05:47 AM
Member ![]() ![]() Group: Members Posts: 359 Joined: 15-June 24 From: Switzerland Member No.: 28,183 Region Association: Europe
Mine are all crushed, and in any case it looks like they weren't the original ones. I'm not going to be ordering them from AA obviously, so I will probably need to make my own. Anyone have the proper dimensions? Looks like the ones I took off were made from slicing something like rubber (fuel?) hose, which is what I might try if I find more or less the right diameter/thickness. ID is probably 6mm. TIA
| dr914@autoatlanta.com |
Dec 3 2025, 10:15 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we had a thousand made to precise specifications
Mine are all crushed, and in any case it looks like they weren't the original ones. I'm not going to be ordering them from AA obviously, so I will probably need to make my own. Anyone have the proper dimensions? Looks like the ones I took off were made from slicing something like rubber (fuel?) hose, which is what I might try if I find more or less the right diameter/thickness. ID is probably 6mm. TIA |
| friethmiller |
Dec 3 2025, 11:15 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,188 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
That decimal needs to slide to the left! (IMG:style_emoticons/default/dry.gif) |
chmillman Valence rubber spacers Dec 3 2025, 05:47 AM
mepstein LOL! I can absolutely imagine ordering them fr... Dec 3 2025, 06:07 AM
porschetub
LOL! I can absolutely imagine ordering them f... Dec 3 2025, 03:11 PM
chmillman
I have a packet of genuine ones part 914-559-127-... Dec 3 2025, 03:13 PM
BillC 914Rubber has them, and probably quite a bit less ... Dec 3 2025, 09:02 AM
sixaddict Oops…didn’t see this was from Switzland so del... Dec 3 2025, 09:13 AM
cassmcentee 914Rubber
https://914rubber.com/spacer-for-rocker-... Dec 3 2025, 09:22 AM
chmillman
914Rubber
[url=https://914rubber.com/spacer-for-r... Dec 3 2025, 12:10 PM
chmillman Well again, ordering from the US is just out of th... Dec 3 2025, 10:07 AM
johnhora Years ago I started using these O size faucet wash... Dec 3 2025, 04:07 PM
chmillman So I went the sliced fuel hose route for now, unti... Dec 4 2025, 11:12 AM
worn
So I went the sliced fuel hose route for now, unt... Dec 7 2025, 06:30 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 12:22 AM |
