| sburns1967 |
Dec 3 2025, 11:27 AM
Newbie ![]() Group: Members Posts: 8 Joined: 16-May 25 From: London, Ontario, Canada Member No.: 28,775 Region Association: Canada |
I have a 1973 914/4 2.0 which is is partially disassembled.
It came with two hot air blowers: Single Port - Working Motor In 1973 there was apparently a switch between the dual outlet blower to a single outlet with a Y pipe. I was thinking I would like to use the dual outlet one so I thought I would swap in the working motor. Two questions: 1) Does the dual outlet unit provide better heat flow through the heat exchangers than the single outlet with a Y connector? Any pointers to pictures of each type mounted/hoses? 2) How to remove the motor: Removed the 6 screws on the motor flange Thanks in advance Scott Attached thumbnail(s) |
| Olympic 914 |
Dec 3 2025, 01:50 PM
![]() ![]() ![]() Group: Members Posts: 1,768 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States
If you have good heat exchangers, there will be enough heat coming into the cabin with the single outlet blower.
I added the Y pipe and hose to the passenger side, but rarely pulled the lever far enough to activate the blower. ( it only comes on at about 3/4 to full on the lever) didn't really like the looks and additional clutter of the hose going to the passenger side. So i removed it and capped that side. As it came originally. I get plenty of heat as it is. |
sburns1967 Heater Blower Motor Dec 3 2025, 11:27 AM
chmillman
I have a 1973 914/4 2.0 which is is partially dis... Dec 3 2025, 11:41 AM
wonkipop
I have a 1973 914/4 2.0 which is is partially di... Feb 8 2026, 01:20 AM
wonkipop in terms of what the factory did with the blowers.... Dec 3 2025, 02:10 PM
dtmehall I have always found that the heat from a single ho... Dec 3 2025, 05:39 PM
sburns1967 Thanks for the info and detailed review of the two... Dec 3 2025, 09:16 PM
DRPHIL914
Thanks for the info and detailed review of the tw... Dec 5 2025, 08:33 AM
sburns1967 I have received the splitter from AA and tried it ... Feb 7 2026, 08:10 PM
chmillman
I have received the splitter from AA and tried it... Feb 8 2026, 12:34 AM
sburns1967
I have a 1973 914/4 2.0 which is is partially dis... Feb 7 2026, 08:22 PM
WFG On the early model the hose going to the passenger... Feb 7 2026, 09:06 PM
Osnabruck914 Move to Florida. I removed my entire blower syste... Feb 7 2026, 09:12 PM
dtmehall except when the iguanas fall down from the cold
... Feb 7 2026, 09:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 8th February 2026 - 03:12 AM |
