| DC_neun_vierzehn |
Nov 22 2025, 05:00 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 628 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
Does anybody have a working clock in their center console? It seems like everyone clock has died.
I bought a reproduction clock from Auto Atlanta and it broke in less than a year. Complete waste of money. Has anybody sent their clock to be rebuilt and if so how did it work out? I think I read somewhere that only 914 clocks with a date stamp of 75 or 76 can be rebuilt as the internals changed? |
| DC_neun_vierzehn |
Dec 1 2025, 03:35 PM
I'm really tempted to crack this thing open (since it's hard to get the multi-meter probes in there) to ensure there's power at the plug
Is there another option for testing for power on this wire other than destroying the OG plastic plug? I removed the entire console and pulled up the carpet ... I didn't see any patching, nicks, or burns on the black wire before it disappeared into the tunnel. Thoughts? Attached thumbnail(s) |
| Puebloswatcop |
Dec 1 2025, 09:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,698 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
I'm really tempted to crack this thing open (since it's hard to get the multi-meter probes in there) to ensure there's power at the plug Is there another option for testing for power on this wire other than destroying the OG plastic plug? I removed the entire console and pulled up the carpet ... I didn't see any patching, nicks, or burns on the black wire before it disappeared into the tunnel. Thoughts? If I recall your car is a '73. If that is correct: The power leading to that connector starts at Fuse 11. From fuse 11 it goes to your interior light on a black and red wire. From your interior light, it goes to that connector on a black wire. So if your interior light is working, I would guess that there is a break in that black wire somewhere between the interior light and the connector for the console. If your interior light is not working, then the issue will be somewhere between your interior light and Fuse 11. |
| DC_neun_vierzehn |
Dec 2 2025, 07:01 AM
I'm really tempted to crack this thing open (since it's hard to get the multi-meter probes in there) to ensure there's power at the plug Is there another option for testing for power on this wire other than destroying the OG plastic plug? I removed the entire console and pulled up the carpet ... I didn't see any patching, nicks, or burns on the black wire before it disappeared into the tunnel. Thoughts? If I recall your car is a '73. If that is correct: The power leading to that connector starts at Fuse 11. From fuse 11 it goes to your interior light on a black and red wire. From your interior light, it goes to that connector on a black wire. So if your interior light is working, I would guess that there is a break in that black wire somewhere between the interior light and the connector for the console. If your interior light is not working, then the issue will be somewhere between your interior light and Fuse 11. Thank you! Interior light works. So this afternoon I will pull out the light from the backpad and inspect/text the wire going to the console from the light. |
| DC_neun_vierzehn |
Dec 4 2025, 10:15 AM
I'm really tempted to crack this thing open (since it's hard to get the multi-meter probes in there) to ensure there's power at the plug Is there another option for testing for power on this wire other than destroying the OG plastic plug? I removed the entire console and pulled up the carpet ... I didn't see any patching, nicks, or burns on the black wire before it disappeared into the tunnel. Thoughts? If I recall your car is a '73. If that is correct: The power leading to that connector starts at Fuse 11. From fuse 11 it goes to your interior light on a black and red wire. From your interior light, it goes to that connector on a black wire. So if your interior light is working, I would guess that there is a break in that black wire somewhere between the interior light and the connector for the console. If your interior light is not working, then the issue will be somewhere between your interior light and Fuse 11. Thank you! Interior light works. So this afternoon I will pull out the light from the backpad and inspect/text the wire going to the console from the light. Good call @Puebloswatcop I had a loose wire at the back pad light. Once I addressed that, I now have power at the clock lead. Time to move on to my next electrical gremlin ... flickering parking lights in the turn signal housing. |
DC_neun_vierzehn Center console clocks Nov 22 2025, 05:00 PM
Shivers This had some info.
http://www.914world.com/bbs2... Nov 22 2025, 05:26 PM
DC_neun_vierzehn
This had some info.
http://www.914world.com/bbs... Nov 30 2025, 11:01 AM
chmillman
Does anybody have a working clock in their center... Nov 23 2025, 02:03 AM
StarBear
Does anybody have a working clock in their cente... Dec 1 2025, 04:29 PM
914Sixer I have 2 clocks with NEW movements. I was going t... Nov 23 2025, 07:00 AM
FlacaProductions I have one that is good to go from a NH Speedo res... Nov 23 2025, 10:49 AM
930cabman Guessin I'm lucky. I have 3 and they all work ... Nov 30 2025, 01:25 PM
DC_neun_vierzehn
Guessin I'm lucky. I have 3 and they all work... Nov 30 2025, 01:54 PM
930cabman
Guessin I'm lucky. I have 3 and they all wor... Nov 30 2025, 07:52 PM
didenpx Volvo had small diameter clocks made by vdo in the... Nov 30 2025, 03:14 PM
DC_neun_vierzehn So while I had my busted clock out I decided to in... Dec 1 2025, 11:20 AM
rfinegan My clock is correct 2 times a day! Dec 1 2025, 01:50 PM
fiacra
I'm really tempted to crack this thing open (... Dec 1 2025, 04:56 PM
fiacra @DC_neun_vierzehn
I have this one in my parts st... Dec 1 2025, 05:36 PM
DC_neun_vierzehn @fiacra
Good tip on that probe kit. I will give ... Dec 1 2025, 07:21 PM
Puebloswatcop
[b]@[url=http://www.914world.com/bbs2/index.php?s... Dec 1 2025, 08:30 PM
DC_neun_vierzehn
[quote name='DC_neun_vierzehn' post='3235132' dat... Dec 2 2025, 06:59 AM
914Sixer This Audi/VW clock is a direct replacement for the... Dec 1 2025, 08:17 PM
914rrr Q: if the clock mechanism is still working, would ... Dec 2 2025, 07:38 AM
Puebloswatcop
Q: if the clock mechanism is still working, would... Dec 2 2025, 08:13 AM
930cabman
Q: if the clock mechanism is still working, woul... Dec 15 2025, 02:58 PM
chmillman I measured this way back when I had a similar issu... Dec 2 2025, 08:06 AM
DC_neun_vierzehn @[url=http://www.914world.com/bbs2/index.php?showu... Dec 15 2025, 12:44 PM
DC_neun_vierzehn I was finally able to cobble together a working an... Jan 1 2026, 02:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 01:46 AM |
