> Hockey Puck Horn Button Confusion. Help!
kenshapiro2002
post Dec 5 2025, 09:38 AM
Just got this 914-6 GT. Horn wasn’t working. It’s a 914 steering wheel with a 911 hockey puck horn button. Pulled off the puck and the horn wire was wrapped in electrical tape. Think I figured out it’s because the base plate and spring plate aren’t isolated from each other. The pin was broken off the base plate. Bought a new base plate and a washer kit. Can’t figure out where the “top hat” shaped plugs go ( I now have six). Do they go in the base plate, the spring plate, or both? And in which direction? I’m truly lost and need kindergarten level instructions here. Thanks!
kenshapiro2002
post Dec 5 2025, 11:31 AM
Ok… got that figured out. Horn is working.
porschetub
post Dec 5 2025, 01:10 PM
QUOTE(kenshapiro2002 @ Dec 6 2025, 05:31 AM) *
There will be six tabs on the chrome trim ring ,remove some of clamping pressure on them ,refit to the wheel in the correct location then turn the leather insert to the exact location .
Remove it and reclamp the six tabs back again ,job done .
kenshapiro2002
post Dec 5 2025, 02:14 PM
QUOTE(porschetub @ Dec 5 2025, 02:10 PM) *
I understand and appreciate, but the button lined up until I removed and reinstalled the guts of the horn button. Maybe ( new rubber piece too) I’m just not turning it forcefully enough. Lemme give it a shot. I can tell it’s not tightly seated.
- Lo-Fi Version Time is now: 12th March 2026 - 02:06 AM
