| kenshapiro2002 |
Dec 5 2025, 09:38 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,486 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
Just got this 914-6 GT. Horn wasn’t working. It’s a 914 steering wheel with a 911 hockey puck horn button. Pulled off the puck and the horn wire was wrapped in electrical tape. Think I figured out it’s because the base plate and spring plate aren’t isolated from each other. The pin was broken off the base plate. Bought a new base plate and a washer kit. Can’t figure out where the “top hat” shaped plugs go ( I now have six). Do they go in the base plate, the spring plate, or both? And in which direction? I’m truly lost and need kindergarten level instructions here. Thanks!
Attached thumbnail(s) |
| kenshapiro2002 |
Dec 5 2025, 11:31 AM
Ok… got that figured out. Horn is working.
| porschetub |
Dec 5 2025, 01:10 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,037 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
| kenshapiro2002 |
Dec 5 2025, 02:14 PM
Ok… got that figured out. Horn is working. There will be six tabs on the chrome trim ring ,remove some of clamping pressure on them ,refit to the wheel in the correct location then turn the leather insert to the exact location . Remove it and reclamp the six tabs back again ,job done . I understand and appreciate, but the button lined up until I removed and reinstalled the guts of the horn button. Maybe ( new rubber piece too) I’m just not turning it forcefully enough. Lemme give it a shot. I can tell it’s not tightly seated. |
| porschetub |
Dec 5 2025, 02:56 PM
Ok… got that figured out. Horn is working. There will be six tabs on the chrome trim ring ,remove some of clamping pressure on them ,refit to the wheel in the correct location then turn the leather insert to the exact location . Remove it and reclamp the six tabs back again ,job done . I understand and appreciate, but the button lined up until I removed and reinstalled the guts of the horn button. Maybe ( new rubber piece too) I’m just not turning it forcefully enough. Lemme give it a shot. I can tell it’s not tightly seated. Mine takes a good firm twist to locate which I believe is correct ,sounds like that will sort yours ,cheers. |
kenshapiro2002 Hockey Puck Horn Button Confusion. Help! Dec 5 2025, 09:38 AM
porschetub
[quote name='kenshapiro2002' post='3235718' date... Dec 5 2025, 02:57 PM
kenshapiro2002 Finally got my horn working but can’t get the pu... Dec 5 2025, 11:34 AM
Superhawk996 Picture? Dec 5 2025, 01:04 PM
kenshapiro2002
Picture?
Dec 5 2025, 01:50 PM
kenshapiro2002
Picture?
My thumb is at the top. The forum t... Dec 5 2025, 01:52 PM
Superhawk996 In an effort to keep all discussion on one thread.... Dec 5 2025, 02:13 PM
kenshapiro2002
In an effort to keep all discussion on one thread... Dec 5 2025, 03:43 PM
kenshapiro2002 Everything is fine now. The wire was getting grabb... Dec 5 2025, 03:46 PM
porschetub
Everything is fine now. The wire was getting grab... Dec 5 2025, 05:28 PM
mepstein Some of them go on pretty tight and one of the rou... Dec 5 2025, 04:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 02:06 AM |
