| neyen14 |
Oct 14 2025, 06:53 PM
Member ![]() ![]() Group: Members Posts: 106 Joined: 2-December 07 From: New York Member No.: 8,408 Region Association: North East States |
This '75 is my second 914, the first was a '72 that was great while it lasted. I bought both rust free cars in New Mexico and was fortunate enough to gather several loads of parts over the years. This '75 is a general conglomeration of things like put together on a 914.
I found an ad on Craigslist posted by an American Muscle Car guy who was threatening to scrap the 1.8L 914 after running the ad several times with no takers. I got it for $500 plus it came with fender flares that were never installed. Attached image(s)
| neyen14 |
Nov 26 2025, 11:48 AM
Does the conduit that the clutch cable goes through in the tunnel only get held in place by the same type of flimsy metal strapping that is used to hold wires in place?
Attached thumbnail(s) |
| barefoot |
Dec 6 2025, 09:30 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,484 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
Does the conduit that the clutch cable goes through in the tunnel only get held in place by the same type of flimsy metal strapping that is used to hold wires in place? My clutch tube had broken free of both supports in the tunnel. Here's my solution for a non-welded fixing. It's an electrical tube clamp slightly blacksmithed to fit the tube dimeter. Then bolted thru tunnel side wall ![]() |
| neyen14 |
Dec 6 2025, 10:33 AM
Does the conduit that the clutch cable goes through in the tunnel only get held in place by the same type of flimsy metal strapping that is used to hold wires in place? My clutch tube had broken free of both supports in the tunnel. Here's my solution for a non-welded fixing. It's an electrical tube clamp slightly blacksmithed to fit the tube dimeter. Then bolted thru tunnel side wall ![]() Thx you, I've gone a similar route. |
neyen14 '75 Silver Metallic Mix & Match Oct 14 2025, 06:53 PM
neyen14 I was told that if I got one, I would get two Oct 14 2025, 07:23 PM
neyen14 911 front suspension and rears drilled to 911 bolt... Oct 14 2025, 07:37 PM
mark04usa Wow...great score. Looks like both may be buildabl... Oct 14 2025, 08:40 PM
neyen14
Wow...great score. Looks like both may be buildab... Oct 15 2025, 04:28 AM
Geezer914 Nice score! Oct 15 2025, 05:27 AM
neyen14 There was a bit of time between the pics in the la... Oct 15 2025, 03:15 PM
fiacra Those more knowledgeable than me will hopefully ch... Nov 26 2025, 03:03 PM
neyen14 Hi everyone. I have these two sets of crossmember ... Dec 4 2025, 06:46 PM
bkrantz Looks like the reinforcement eliminates the little... Dec 4 2025, 08:02 PM
neyen14
Looks like the reinforcement eliminates the littl... Dec 5 2025, 06:21 AM
Root_Werks What a great score! Both look solid from the ... Dec 5 2025, 11:57 AM
neyen14
What a great score! Both look solid from the... Dec 5 2025, 04:15 PM
Jack Standz Quote from above:
"Hi everyone. I have these... Dec 6 2025, 12:21 PM
neyen14
Quote from above:
"Hi everyone. I have thes... Dec 7 2025, 08:01 AM
jim_hoyland Great work :) Thanks for sharing… Dec 7 2025, 09:27 PM
neyen14 Today I started the engine (in the car) for the fi... Jan 21 2026, 06:14 PM
neyen14 I'm currently using the taller piston on the r... Jan 21 2026, 07:55 PM
porschetub Those taller pistons look like old NPR or AA perfo... Jan 22 2026, 11:53 PM
neyen14
Those taller pistons look like old NPR or AA perf... Feb 4 2026, 12:03 PM
porschetub
Those taller pistons look like old NPR or AA per... Feb 7 2026, 04:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 03:56 AM |
