| chmillman |
Oct 16 2025, 04:56 AM
Member ![]() ![]() Group: Members Posts: 392 Joined: 15-June 24 From: Switzerland Member No.: 28,183 Region Association: Europe
Thinking about pulling my rocker panels and having them repainted - they are looking a bit dingy and grayish. Plus all the discussions here about looking underneath…
They are currently held on by the plastic rivets - I think - they don’t look great and probably not salvageable. I thought I would put the panels back on with pop rivets, which seem like a more solid solution - black ones are available - I don’t mind having to drill them out if I want to remove the panels again at a later date. I don’t anticipate doing it often. Is there anything that argues strongly against this? |
| rgalla9146 |
Dec 8 2025, 02:45 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,033 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Depends on your car and how strict you are. My 1970 has white plastic rivets as original. I don't know if they're available today. Stock later cars with black plastic thresholds get black plastic rivets. Or whatever suits you for cleaning and maintenance. |
chmillman Rocker panel rivets Oct 16 2025, 04:56 AM
emerygt350 I use aluminum rivets, drill out real easy. I hav... Oct 16 2025, 05:12 AM
bdstone914 I just installed a set with aluminum pop rivets. I... Oct 16 2025, 05:14 AM
Millerwelds I am in the process of replacing all the miss mat... Oct 16 2025, 06:06 AM
cassmcentee I used Rivnuts and stainless hex bolts (same bolts... Oct 16 2025, 06:04 AM
930cabman I use aluminum pop rivets, a dab of black paint on... Oct 16 2025, 02:38 PM
chmillman OK, thanks all, I can easily get black ones here a... Oct 16 2025, 02:47 PM
Front yard mechanic Black screws easy on and off ( stupid little plast... Oct 17 2025, 06:22 AM
bdstone914
Black screws easy on and off ( stupid little plas... Oct 17 2025, 07:19 AM
rick 918-S 914 Rubber has the plastic Rivets Oct 17 2025, 06:33 AM
Root_Werks Dunno if this helps, I'm using SS rockers whic... Oct 17 2025, 09:31 AM
FlacaProductions @Root_Werks - did the stainless come pre-drilled ... Oct 17 2025, 09:53 AM
Root_Werks
[b]@[url=http://www.914world.com/bbs2/index.php?s... Oct 17 2025, 10:12 AM
Literati914
Black screws easy on and off ( stupid little pla... Oct 17 2025, 11:02 AM
bkrantz
[quote name='bdstone914' post='3228657' date='Oct... Oct 17 2025, 08:04 PM
Montreal914 @chmillman
Not sure you got your answer on the h... Oct 17 2025, 11:10 AM
FlacaProductions @Root_Werks - thanks - that's helpful. Oct 17 2025, 11:15 AM
chmillman In the end I went with screws - because I found th... Dec 8 2025, 05:26 AM
Aayala
In the end I went with screws - because I found t... Dec 8 2025, 10:40 AM
chmillman
Do you mind taking a picture of where you install... Dec 9 2025, 04:17 AM
DennisV
My 1970 has white plastic rivets as origina... Dec 9 2025, 08:19 AM
914werke When the rocker & sill are in good condition t... Dec 11 2025, 06:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th November 2026 - 04:22 AM |
