> No F-ing oil baffle on my new to me engine block!, Do I need to return the engine case or is there some option?
flxzcat
post Dec 8 2025, 06:57 PM
Guys,
I am building a 2.4 engine for my lightweight canyon carver.
I picked up a reworked, ready to final clean and assemble case from "EMS" in L.A.
After doing much work including clearancing of the case, I realized that there were no slots for mounting the baffle? "G" knew exactly what I was planning for this case.
Is there some option or will I have to return the case and start over (IMG:style_emoticons/default/headbang.gif)
Thanks in advance,
Paul VDL
Jack Standz
post Dec 8 2025, 10:50 PM
Well, sorry to hear you didn't get what you wanted. It does, look like your case has the thicker/stronger and more desirable deck for a larger 2.4 liter motor.
The case I'm working on lately is a "W" case but, does have the provisions for a windage tray (or oil slosh tray if you prefer). Yours must be an early '72 or earlier?
As already mentioned, a dry sump is an (expensive) option. You could extend the push rod tubes or run so called "windage" tubes like those used in formula V by the type 1 guys. Get a deep sump and run an extended oil pickup, fill it with less oil (?).
Good luck with your project!
flxzcat   No F-ing oil baffle on my new to me engine block!   Dec 8 2025, 06:57 PM
Superhawk996   Well that’s a bummer. Dry sump. :shades2:   Dec 8 2025, 07:45 PM
GregAmy   Dry sump. :shades2: This is the way.   Dec 9 2025, 10:28 PM
wonkipop   Dry sump. :shades2: This is the way. either t...   Dec 10 2025, 06:11 AM
GregAmy   either that or avoid sweepers. :D why i got s...   Dec 10 2025, 10:21 AM
JamesJ   If you are referring to EMW, I am not surprised at...   Dec 8 2025, 09:30 PM
Jack Standz   Well, sorry to hear you didn't get what you wa...   Dec 8 2025, 10:50 PM
Jack Standz   And there's always the opinion that windage tr...   Dec 8 2025, 11:16 PM
bdstone914   @flxzcat Did you call George and discuss it with...   Dec 9 2025, 04:53 AM
cgnj   Looking at that picture of the case, I have questi...   Dec 9 2025, 07:44 AM
flxzcat   Looking at that picture of the case, I have quest...   Dec 9 2025, 12:34 PM
flxzcat   I am thinking I should run the "deep sump...   Dec 9 2025, 01:46 PM
Superhawk996   I am thinking I should run the "deep sump...   Dec 10 2025, 09:07 AM
Jack Standz   Current plan is to run a deep sump with a modified...   Dec 9 2025, 03:33 PM
flxzcat   Agree oil starvation is primary. Seems to me, the ...   Dec 9 2025, 04:32 PM
Ninja   There was a mod recently shown on the forum which ...   Dec 9 2025, 04:54 PM
Ninja   Raby's baffles had many more drainage slots. T...   Dec 9 2025, 05:01 PM
flxzcat   There was a mod recently shown on the forum which...   Dec 9 2025, 07:00 PM
914werke   RE: No F-ing oil baffle on my new to me engine block!   Dec 9 2025, 07:29 PM
914werke   RE: No F-ing oil baffle on my new to me engine block!   Dec 9 2025, 07:32 PM
Jack Standz   Here's one version of a modified windage tray,...   Dec 9 2025, 07:59 PM
Shivers   Here's one version of a modified windage tray...   Dec 10 2025, 06:50 AM
burton73   Just for reference, this is a Raby Modified winda...   Dec 10 2025, 01:20 PM
Jack Standz   Thanks for sharing Bob! That looks like how I...   Dec 10 2025, 03:36 PM
- Lo-Fi Version Time is now: 3rd March 2026 - 01:07 AM
