> Very original 6 on BAT, Quite the example
gereed75
post Dec 3 2025, 06:12 PM
https://bringatrailer.com/listing/1970-porsche-914-6-115/
After just a cursory review of the pix this appears to be one of the most complete original sixes I have seen
Incredible what is on this car and even what is not. Have never seen an original intact cold start valve and piping on a car. Have never seen the original fuel vapor system intact. No sway bars. 14” Fuchs.
Could that be original paint?
This will be an indicator of potential value of such a car. Pretty exceptional.
johnhora
post Dec 8 2025, 04:20 PM
wonkipop
Great info you found...
This will add a little to that conclusion:
My 914-6 9140432060 is a 5/70 production date that was delivered in Louisville KY and is 22 cars down the line after the one for sale and mine doesn't have any evaporation system equipment or modifications and the fuel tank does not have the charcoal canister brackets. Apparently Porsche had a pretty good idea of where the 6's were going and didn't put anything on them not required or on the build sheet.
This yellow 914-6 will be a very nice car for someone.
wonkipop
post Dec 9 2025, 02:04 PM
QUOTE(johnhora @ Dec 8 2025, 04:20 PM) *
wonkipop
yes - exactly. i would have thought a fair proportion of the 6s would have been customer ordered as you say. and porsche knew where they were being delivered to. built to exact regulation requirements and no more when it came to emissions gear. some of course would have been general showroom stock but a lot would not have been.
the 4s were likely a very different story. a lot more general spec stuff as the expectation would have been mass sales. proportion of showroom stock to personal customer orders would have been significantly different you would think. hence logic of a more universal all states inclusive of california conformity for 4s?
not entirely unrelated is the actual layout of those carbon cannisters in the 914s.
both the 6s and the 4s. which is something we got deep into with the 1.8 L jet research, completely inadvertently. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) the hook up of the hoses to the cannisters is entirely a porsche design - same as used in the 911s of the time. the hose from the fan and the hose to the carbs was inverted when compared to the VW design layout used on every VW except the 914/4. but the same components were used by both companies.
same cannister that is. turns out the porsche layout is tuned for carbs and the vapor load that comes out of carbi bowls on hot shutdown. thats the problem porsche had with its carb cars. for VW this problem did not exist, they had EFI, no hot shutdown vapor load at the engine inlet side of things. the vapor load was nearly entirely from the fuel tank. the VW design was tuned for maximum life of the cannister, the porsche design was to cope with the carbs and make it through the EPA test. porsche would have seen the cannister as a service item with much shorter replacement times. conveniently located in front trunk for quick replacement. VW hid these cannisters in all sorts of less convenient locations on all their other regular models.
in 1974 the 914 finally changed to the VW layout with the engine bay cannisters fitted to the 1974 L jets. from then on all the 914 models used the revised VW standard layout.
it was one of those funny little things where the early 914/4s could have had the VW layout with a different hose hook up to the 6s but instead a standard porsche layout was used for all the cars.
interestingly porsche themselves switched to the VW layout on the 911s in 74 model year as well. why? because they went to fuel injection and dropped carbs entirely for the USA market by that point. so they too could finally tune the cans for long life rather than just coping with the EPA test for certification.
however in neither case did the cans achieve the 50,000 mile warranty provision the EPA required. all were noted as 30,000 mile changeover replacement items. little known and forgotten now but if your car had done more than 30,000 miles but less than 50,000 miles and was less than 5 years old the can was a free of charge warranty part replacement. regulations required the manufacturer to do that. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif)
gereed75   Very original 6 on BAT   Dec 3 2025, 06:12 PM
flipb   https://bringatrailer.com/listing/1970-porsche-91...   Dec 3 2025, 07:02 PM
Cupomeat   6 Days and sitting at USD $20,914... Lots o...   Dec 3 2025, 07:11 PM
rgalla9146   As good as can be. Love the original yellowi...   Dec 3 2025, 08:53 PM
sixaddict   I just spent over an hour getting reference pictur...   Dec 3 2025, 11:32 PM
morehills   Plastic fuel lines? Yikes. Let's not be a sl...   Dec 4 2025, 05:01 AM
flyer86d   So that is what my -6 is supposed to look like. Al...   Dec 4 2025, 05:29 AM
emerygt350   https://www.facebook.com/marketplace/item/18366912...   Dec 4 2025, 08:35 AM
Tom1394racing   The seller is Mark Burkit of Specialty Cars in All...   Dec 4 2025, 09:23 AM
Cairo94507   That is an absolute Gem! :beer2:   Dec 4 2025, 09:39 AM
DennisV   I see fog lights, but no fog light switch on the d...   Dec 4 2025, 09:52 AM
sixaddict   Is this correct……not to be critical just try...   Dec 4 2025, 10:02 AM
Root_Werks   Looks very original and clean.   Dec 4 2025, 10:07 AM
gereed75   Pretty sure the lines in the drivers rocker are pa...   Dec 4 2025, 12:14 PM
eric9144   Is this correct……not to be critical just tryi...   Dec 4 2025, 12:23 PM
rgalla9146   I think the power antenna and Becker radio are not...   Dec 4 2025, 12:27 PM
wonkipop   I think the power antenna and Becker radio are no...   Dec 6 2025, 09:21 PM
DennisV   so....its highly possible that 914s (possibly bot...   Dec 7 2025, 07:50 AM
johnhora   Very nice example of a 914-6 Well documented rebui...   Dec 4 2025, 12:55 PM
sixaddict   I was assuming that was a power antenna but I have...   Dec 4 2025, 12:55 PM
Dave_Darling   Have never seen an original intact cold start va...   Dec 6 2025, 04:58 PM
JeffBowlsby   I dunno if I agree with that DD, as the options li...   Dec 6 2025, 06:08 PM
DennisV   I dunno if I agree with that DD, as the options l...   Dec 7 2025, 05:41 PM
davep   This car was specced as C13 for California & N...   Dec 6 2025, 09:09 PM
rgalla9146   I've owned two California delivery cars (1467,...   Dec 6 2025, 10:33 PM
campbellcj   This one really tugs at me as I'd love to have...   Dec 7 2025, 08:16 AM
Cfletch   My build date 12.69 car was sold in vegas new and ...   Dec 7 2025, 11:42 AM
wonkipop   @rgalla9146 & [b]@[url=http://www.914world.c...   Dec 7 2025, 12:39 PM
DennisV   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Dec 7 2025, 05:37 PM
fixer34   [b]@[url=http://www.914world.com/bbs2/index.php?...   Dec 7 2025, 09:08 PM
wonkipop   @rgalla9146 i checked up what i had on file. mos...   Dec 7 2025, 02:32 PM
rgalla9146   Cars with charcoal cans and vapor plumbing have pa...   Dec 7 2025, 03:16 PM
wonkipop   Cars with charcoal cans and vapor plumbing have p...   Dec 7 2025, 03:46 PM
rudedude   My march ‘70 #729 has the lines and charcoal can...   Dec 7 2025, 10:40 PM
Cairo94507   My '71 with a May '71 production has a cha...   Dec 8 2025, 08:23 AM
gandalf_025   My car, # 619.. Sold new in Massachusetts Built 2...   Dec 8 2025, 09:46 AM
wonkipop   ok - think i found the answer to the charcoal can ...   Dec 8 2025, 02:55 PM
johnhora   wonkipop Great info you found... This will add a...   Dec 8 2025, 04:20 PM
wonkipop   wonkipop Great info you found... This will add ...   Dec 9 2025, 02:04 PM
wonkipop   another one for you 914/6 original condition geeks...   Dec 9 2025, 01:35 PM
gandalf_025   My car never had vent screens.. Build date 2/70   Dec 9 2025, 02:19 PM
wonkipop   My car never had vent screens.. Build date 2/70 ...   Dec 10 2025, 06:05 AM
JeffBowlsby   You know Michael, my only concern with the two dif...   Dec 9 2025, 02:20 PM
wonkipop   You know Michael, my only concern with the two di...   Dec 9 2025, 03:07 PM
JeffBowlsby   Would you agree that the plastic charcoal cans, as...   Dec 9 2025, 03:28 PM
wonkipop   Would you agree that the plastic charcoal cans, a...   Dec 9 2025, 04:21 PM
Cairo94507   I have owned 2 '70 914-6's and my current ...   Dec 9 2025, 03:21 PM
wonkipop   @JeffBowlsby the joke down here now jeff is we h...   Dec 9 2025, 03:26 PM
JeffBowlsby   Thanks for the extra detail - engine intake vacuum...   Dec 9 2025, 05:14 PM
wonkipop   Thanks for the extra detail - engine intake vacuu...   Dec 10 2025, 04:14 AM
wonkipop   @JeffBowlsby here is the diagram for EVAP i foun...   Dec 10 2025, 04:49 AM
rick 918-S   What I am wondering about is why a car that nice i...   Dec 10 2025, 07:04 AM
gandalf_025   I'm pretty sure the price of that car will go ...   Dec 10 2025, 10:00 AM
ctc911ctc   I'm pretty sure the price of that car will go...   Dec 10 2025, 01:40 PM
Steve   And didn’t make the reserve. I wonder if it wou...   Dec 10 2025, 02:41 PM
rgalla9146   I'll bet the reserve was 100k I think th...   Dec 10 2025, 03:18 PM
johnhora   I'll bet the reserve was 100k I think t...   Dec 10 2025, 03:23 PM
sixaddict   Pre Christmas pretty much bad time to sell stuff...   Dec 10 2025, 03:25 PM
914043   dr914 please share your pick list on this beautifu...   Dec 11 2025, 03:24 PM
dr914@autoatlanta.com   I have one, but did it for a client who paid for i...   Dec 11 2025, 04:08 PM
- Lo-Fi Version Time is now: 3rd March 2026 - 01:03 AM
