| Ron914 |
Dec 9 2025, 02:36 PM
Member ![]() ![]() Group: Members Posts: 492 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California
In preparation for my smog test I hope to get this week I need to install the Decel valve as it is original equipment and required . I am trying to understand how the decel valve works and where it should be set .
My understanding (and correct me if I am wrong ) is when the vacuum in the plenum goes high the valve opens and creates a path between the plenum and the air cleaner , this is controlled by the decel valve but at what value . If I lift on the accelerator the vacuum in the plenum goes high thus creating a connection between the plenum and the air intake or cleaner . I would assume you set it high vacuum ( maybe 18-22inHg)I checked the tech notes section for an explanation but could not find what I am looking for . I am actually thinking about screwing in the adjustment screen so that the decel never opens , however it will still appear connected . I doubt they will be checking the actual operation of it . |
emerygt350 Mine was set around 23 psi. I think many around h... Dec 9 2025, 02:46 PM
rjames As emeryGT said, stock setting is ~18 inHg. Keepi... Dec 9 2025, 03:09 PM
Ron914 Thanks Robert and Dan ,
When I first got the motor... Dec 9 2025, 03:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:34 PM |
