| gereed75 |
Dec 3 2025, 06:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,420 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States
https://bringatrailer.com/listing/1970-porsche-914-6-115/
After just a cursory review of the pix this appears to be one of the most complete original sixes I have seen Incredible what is on this car and even what is not. Have never seen an original intact cold start valve and piping on a car. Have never seen the original fuel vapor system intact. No sway bars. 14” Fuchs. Could that be original paint? This will be an indicator of potential value of such a car. Pretty exceptional. |
| JeffBowlsby |
Dec 9 2025, 05:14 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,198 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Thanks for the extra detail - engine intake vacuum pulls and engine fan pushes the fuel vapor laden air thru the can into the engine intake manifold. Simple enough.
The intake vacuum should be ~-15-20 in/hg in a healthy engine right? I would be curious to know what the engine fan pressure supplied is and how it compares to the intake vacuum. It’s not critical though as they both do the same thing. In fact if the intake manifold vacuum is sufficient, the engine fan air would be redundant and unnecessary. Either way the can is a plenum with only three ports. Fuel vapor is supplied from only one port, from the fuel tank. Carbed cars may have a different fuel vapor source…the subject has not been discussed before, so I am thinking conceptually. The other two ports in the can either vacuum out the air in the can by applying intake manifold vacuum (purging) or by pushing air out of the can by positive engine fan air pressure. Both sources direct the fuel vapor laden air into the intake manifold. The basic issue then is that as long as fuel vapor laden air is directed through the charcoal media, either pushed or pulled though it, then the can is functioning to cleanse the airflow. My diagram requires the air to flow through all of the media, it has no other route. If the can is plumbed such that the small fuel vapor supply hose is at the same end of the can as the port to the intake manifold vacuum, then the fuel vapor only permeates the media at one end of the can and filtering would be much less effective. Basically a short circuit. This effect would be magnified by the engine air fan pushing air into the media, which further reduces fuel vapor permeation into the media. Conceptually, with both air movement sources, it would not matter how the can is plumbed. Fuel vapor can only be drawn into the can, the other two direct the air out, into the engine intake. One configuration may be more effective than the other, depending on the airflow balance directing air into the intake manifold. What am I missing here? |
gereed75 Very original 6 on BAT Dec 3 2025, 06:12 PM
flipb
https://bringatrailer.com/listing/1970-porsche-91... Dec 3 2025, 07:02 PM
Cupomeat 6 Days and sitting at USD $20,914...
Lots o... Dec 3 2025, 07:11 PM
rgalla9146 As good as can be.
Love the original yellowi... Dec 3 2025, 08:53 PM
sixaddict I just spent over an hour getting reference pictur... Dec 3 2025, 11:32 PM
morehills Plastic fuel lines? Yikes. Let's not be a sl... Dec 4 2025, 05:01 AM
flyer86d So that is what my -6 is supposed to look like. Al... Dec 4 2025, 05:29 AM
emerygt350 https://www.facebook.com/marketplace/item/18366912... Dec 4 2025, 08:35 AM
Tom1394racing The seller is Mark Burkit of Specialty Cars in All... Dec 4 2025, 09:23 AM
Cairo94507 That is an absolute Gem! :beer2: Dec 4 2025, 09:39 AM
DennisV I see fog lights, but no fog light switch on the d... Dec 4 2025, 09:52 AM
sixaddict
Is this correct……not to be critical just try... Dec 4 2025, 10:02 AM
Root_Werks Looks very original and clean. Dec 4 2025, 10:07 AM
gereed75 Pretty sure the lines in the drivers rocker are pa... Dec 4 2025, 12:14 PM
eric9144
Is this correct……not to be critical just tryi... Dec 4 2025, 12:23 PM
rgalla9146 I think the power antenna and Becker radio are not... Dec 4 2025, 12:27 PM
wonkipop
I think the power antenna and Becker radio are no... Dec 6 2025, 09:21 PM
DennisV
so....its highly possible that 914s (possibly bot... Dec 7 2025, 07:50 AM
johnhora Very nice example of a 914-6
Well documented rebui... Dec 4 2025, 12:55 PM
sixaddict I was assuming that was a power antenna but I have... Dec 4 2025, 12:55 PM
Dave_Darling Have never seen an original intact cold start va... Dec 6 2025, 04:58 PM
JeffBowlsby I dunno if I agree with that DD, as the options li... Dec 6 2025, 06:08 PM
DennisV
I dunno if I agree with that DD, as the options l... Dec 7 2025, 05:41 PM
davep This car was specced as C13 for California & N... Dec 6 2025, 09:09 PM
rgalla9146 I've owned two California delivery cars (1467,... Dec 6 2025, 10:33 PM
campbellcj This one really tugs at me as I'd love to have... Dec 7 2025, 08:16 AM
Cfletch My build date 12.69 car was sold in vegas new and ... Dec 7 2025, 11:42 AM
wonkipop @rgalla9146 & [b]@[url=http://www.914world.c... Dec 7 2025, 12:39 PM
DennisV
[b]@[url=http://www.914world.com/bbs2/index.php?s... Dec 7 2025, 05:37 PM
fixer34
[b]@[url=http://www.914world.com/bbs2/index.php?... Dec 7 2025, 09:08 PM
i checked up what i had on file.
mos... Dec 7 2025, 02:32 PM
rgalla9146 Cars with charcoal cans and vapor plumbing have pa... Dec 7 2025, 03:16 PM
wonkipop
Cars with charcoal cans and vapor plumbing have p... Dec 7 2025, 03:46 PM
rudedude My march ‘70 #729 has the lines and charcoal can... Dec 7 2025, 10:40 PM
Cairo94507 My '71 with a May '71 production has a cha... Dec 8 2025, 08:23 AM
gandalf_025 My car, # 619.. Sold new in Massachusetts
Built 2... Dec 8 2025, 09:46 AM
wonkipop ok - think i found the answer to the charcoal can ... Dec 8 2025, 02:55 PM
johnhora wonkipop
Great info you found...
This will add a... Dec 8 2025, 04:20 PM
wonkipop
wonkipop
This will add ... Dec 9 2025, 02:04 PM
wonkipop another one for you 914/6 original condition geeks... Dec 9 2025, 01:35 PM
gandalf_025 My car never had vent screens.. Build date 2/70 Dec 9 2025, 02:19 PM
wonkipop
... Dec 10 2025, 06:05 AM
JeffBowlsby You know Michael, my only concern with the two dif... Dec 9 2025, 02:20 PM
wonkipop
You know Michael, my only concern with the two di... Dec 9 2025, 03:07 PM
JeffBowlsby Would you agree that the plastic charcoal cans, as... Dec 9 2025, 03:28 PM
wonkipop
Would you agree that the plastic charcoal cans, a... Dec 9 2025, 04:21 PM
Cairo94507 I have owned 2 '70 914-6's and my current ... Dec 9 2025, 03:21 PM
wonkipop @JeffBowlsby
the joke down here now jeff is we h... Dec 9 2025, 03:26 PM
wonkipop
Thanks for the extra detail - engine intake vacuu... Dec 10 2025, 04:14 AM
here is the diagram for EVAP i foun... Dec 10 2025, 04:49 AM
rick 918-S What I am wondering about is why a car that nice i... Dec 10 2025, 07:04 AM
gandalf_025 I'm pretty sure the price of that car will go ... Dec 10 2025, 10:00 AM
ctc911ctc
I'm pretty sure the price of that car will go... Dec 10 2025, 01:40 PM
Steve And didn’t make the reserve. I wonder if it wou... Dec 10 2025, 02:41 PM
rgalla9146 I'll bet the reserve was 100k
I think th... Dec 10 2025, 03:18 PM
johnhora
I think t... Dec 10 2025, 03:23 PM
sixaddict Pre Christmas pretty much bad time to sell stuff... Dec 10 2025, 03:25 PM
914043 dr914 please share your pick list on this beautifu... Dec 11 2025, 03:24 PM
dr914@autoatlanta.com I have one, but did it for a client who paid for i... Dec 11 2025, 04:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 01:03 AM |
