| Ron914 |
Dec 9 2025, 06:51 PM
Member ![]() ![]() Group: Members Posts: 481 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California
In preparation and hope that I pass my smog test I want to go on the So. Cal.Toy Drive in my 914 on Saturday (not sure if this is a good idea) .
I need to address what I think might be a high oil temp problem . After driving around town for 30 minutes the photo shows my oil temperature oil gauge and a actual thermometer reading using a turkey fryer thermometer. The needle on my console gauge gets very close to the red high mark and sometimes just about to cross into the red . At this point the turkey thermometer reads ~216 F degrees . My Dakota Digital head cylinder temperature reads 111C (231F) . It is almost 80F here today in sunny So Cal. but this seems too high for me . What would be a normal reading for the oil temp gauge? This is a newly rebuilt motor (less than 300 miles on it). I did not replace the oil cooler (its original) but it was flushed and was clear. The baffles are held open by spring tension since the thermostat is not working but I checked they were open by removing the coil and checking through the bolt hole. This should be ok until I get a chance to replace it . If I pass my smog check tomorrow or Thursday I am hesitant to take the car on a long canyon drive , so not sure if I can attend the toy drive this Saturday. Any thoughts ? |
| dtmehall |
Dec 9 2025, 08:57 PM
Member ![]() ![]() Group: Members Posts: 250 Joined: 21-December 23 From: Farmington Hills, Michigan Member No.: 27,808 Region Association: Upper MidWest |
superhawk
are you discounting that oil pressure might be a relevant data point? |
| Superhawk996 |
Dec 9 2025, 09:08 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,730 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
superhawk are you discounting that oil pressure might be a relevant data point? Nope not at all. It’s important. Excessive pressure just causes the bypass valve to open fully bypassing the cooler, and dumping excess flow back to the sump. Would be awesome to just put a mechanical gauge on it if need be. Was just trying not to overwhelm Ron with all the variables. |
Ron914 High Oil temperature Dec 9 2025, 06:51 PM
brant It’s not broke in yet
It will come down if only ... Dec 9 2025, 06:59 PM
worn
It will come down if only... Dec 9 2025, 07:03 PM
brant
It will come down if onl... Dec 10 2025, 04:18 PM
Ron914
It will come down if only... Dec 9 2025, 07:53 PM
Superhawk996 Do you have the stock 200c temp sensor? Dec 9 2025, 07:38 PM
Ron914
Yes I do... Dec 9 2025, 07:40 PM
Superhawk996
Yes I d... Dec 9 2025, 07:47 PM
Ron914
[quote name='Ron914' post='3236265' date='Dec 9 2... Dec 9 2025, 08:07 PM
bkrantz 10W-30 might be too thin. Dec 9 2025, 08:01 PM
dtmehall what does your oil pressure run cold/hot, idle/at ... Dec 9 2025, 08:28 PM
Ron914
what does your oil pressure run cold/hot, idle/at... Dec 9 2025, 08:39 PM
Superhawk996 When the engine is cold (as in overnight cold) it ... Dec 9 2025, 08:51 PM
dtmehall :agree: Dec 9 2025, 09:13 PM
Superhawk996 Posting this just for clarity on how temperature, ... Dec 9 2025, 09:27 PM
Dave_Darling The temp gauge on the center console is not super ... Dec 10 2025, 02:45 AM
Geezer914 2056 motor, 9:1 cr., biral cylinders, Tangerine oi... Dec 10 2025, 07:17 AM
930cabman
2056 motor, 9:1 cr., biral cylinders, Tangerine o... Dec 10 2025, 04:03 PM
Geezer914
2056 motor, 9:1 cr., biral cylinders, Tangerine ... Dec 10 2025, 04:39 PM
Ron914
[quote name='930cabman' post='3236378' date='Dec ... Dec 11 2025, 08:59 AM
Ron914
2056 motor, 9:1 cr., biral cylinders, Tangerine ... Dec 11 2025, 08:53 AM
Superhawk996
I need to find a dual sender so I can hook up the... Dec 11 2025, 09:31 AM
930cabman
I need to find a dual sender so I can hook up th... Dec 12 2025, 06:55 PM
emerygt350 I agree with the 50 weight hypothesis. I would tr... Dec 11 2025, 07:20 AM
brant Too early for synthetic
I would put 1000 miles o... Dec 11 2025, 07:28 AM
emerygt350
I would put 1000 miles ... Dec 11 2025, 07:51 AM
Superhawk996 Because the receipt says oil pump and cover we kno... Dec 11 2025, 09:39 AM
Superhawk996 I’m also going to write this for your benefit de... Dec 11 2025, 09:49 AM
930cabman
I’m also going to write this for your benefit d... Dec 11 2025, 10:23 AM
73-914
I’m also going to write this for your benefit d... Dec 11 2025, 11:45 AM
JamesM
Tying to make an air cooled engines run at 180F... Dec 11 2025, 09:44 PM
Ninja
I’m also going to write this for your benefit d... Dec 11 2025, 03:29 PM
Ninja Sorry, forum's been glitchy for me recently... Dec 11 2025, 03:29 PM
Ron914
Sorry, forum's been glitchy for me recently..... Dec 11 2025, 05:24 PM
emerygt350 Getting the oil over 210, as mentioned is importan... Dec 11 2025, 03:46 PM
Ron914 I made a couple of more temperature readings when ... Dec 11 2025, 06:24 PM
Superhawk996
Thoughts of abandoning this project are floating... Dec 11 2025, 08:17 PM
emerygt350 I think the turkey thermometer is probably as good... Dec 12 2025, 06:07 AM
930cabman
I think the turkey thermometer is probably as goo... Dec 12 2025, 06:58 PM
Ninja
[quote name='Ninja' post='3236494' date='Dec 11 2... Dec 13 2025, 01:55 PM
Ninja The double post gremlin is very active with me now... Dec 13 2025, 01:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 01:10 AM |
