> Why does my left turn signal work without the brake on but once I apply the brake, it does not work?
914xr75
post Dec 9 2025, 10:53 AM
So when I’m just turning left without applying the brakes, the front and back turn signals work as they should. With the brake applied the turn signals do not blink.
The right side works correctly. It’s a 1973 model.
I did install the Spoke led front turn signal boards but I’m not sure if it did the same thing before the LED change. I only noticed because a car behind honked at me when I was turning left.
Any ideas for this problem would be appreciated.
Dave_Darling
post Dec 10 2025, 02:52 AM
914 Idiot
You've got one of the turn signal buckets mis-wired. Could be front, could be rear.
Time to dig into the LED swap you did and carefully check where everything is hooked up.
--DD
- Lo-Fi Version Time is now: 3rd March 2026 - 01:06 AM
