| Blue Lightning |
Dec 7 2025, 04:47 PM
Member ![]() ![]() Group: Members Posts: 77 Joined: 7-December 23 From: Atlanta, GA, USA Member No.: 27,780 Region Association: South East States |
1976 2.0. Putting engine back in after a 2056-dectomy, but it has been out too long and as usual I didn't take enough pictures of all the important connections.
There are many threads on wiring for the starter. However, I have one additional wire that I don't see in any of those threads, but I marked as going to the starter solenoid. Wire in my hand: ![]() Way off to right: ![]() Out of focus in center: The wire in question is red and has a spade terminal on the end. It is not the cable that runs from the alternator. My best guess as of today is that is leads up to the firewall and goes through here: Thoughts? Car has air conditioning, so is this part of that? |
| Superhawk996 |
Dec 10 2025, 09:26 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,730 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
In response to OP original question - you’re going to have to trace the wire. There are no OEM stock wires exiting directly out of that area of the bulkhead. Some one did a “custom” job.
Blue Lightning Starter Wiring Dec 7 2025, 04:47 PM
Jack Standz Your car looks different because it's been mod... Dec 7 2025, 06:27 PM
Blue Lightning
Your car looks different because it's been mo... Dec 7 2025, 09:33 PM
Rob-O Follow it through the engine tin. Where does it g... Dec 8 2025, 09:54 AM
Blue Lightning
Follow it through the engine tin. Where does it ... Dec 8 2025, 01:46 PM
Dlee6205
Agreed my car has the "hot start" mod.... Dec 8 2025, 02:05 PM
Blue Lightning
The answer to your question is we don't know.... Dec 8 2025, 03:52 PM
Spoke
1976 2.0. Putting engine back in after a 2056-de... Dec 8 2025, 02:42 PM
Dlee6205 I just saw where you said your car has AC... its e... Dec 8 2025, 03:09 PM
emerygt350 That is a beefy wire. The mod grounds to the case... Dec 8 2025, 06:51 PM
Blue Lightning
That is a beefy wire. The mod grounds to the cas... Dec 9 2025, 07:45 AM
930cabman Waay to messy for me, I would lose the Ford relay ... Dec 8 2025, 06:54 PM
Blue Lightning
Waay to messy for me, I would lose the Ford relay... Dec 9 2025, 07:47 AM
Blue Lightning :sawzall: Dec 9 2025, 08:01 AM
emerygt350 But doesn't address the problem of the mystery... Dec 9 2025, 06:00 AM
emerygt350 Hopefully you would use a relay but maybe they wer... Dec 9 2025, 02:49 PM
emerygt350 Check the resistance on it and maybe send 12v? Ki... Dec 9 2025, 02:50 PM
Literati914 You got it looking like this (see pic) at the Sole... Dec 9 2025, 03:22 PM
Blue Lightning
You got it looking like this (see pic) at the Sol... Dec 14 2025, 07:42 PM
emerygt350 Just tried staring at your picture again. I think... Dec 9 2025, 05:43 PM
Blue Lightning
Just tried staring at your picture again. I thin... Dec 14 2025, 07:44 PM
chmillman How much current does the original solenoid draw a... Dec 10 2025, 05:00 AM
Superhawk996
How much current does the original solenoid draw ... Dec 10 2025, 09:23 AM
chmillman
[quote name='chmillman' post='3236299' date='Dec ... Dec 10 2025, 09:47 AM
Superhawk996
The solenoid or the starter...??? I can't ... Dec 10 2025, 09:49 AM
chmillman
I’ve measured it with an accurate shunt resisto... Dec 10 2025, 11:37 AM
Blue Lightning
How much current does the original solenoid draw... Dec 14 2025, 07:57 PM
Spoke Found this schematic for the Ford relay conversion... Dec 10 2025, 09:03 AM
emerygt350 The amperage is only part of the issue. The Bosch... Dec 10 2025, 01:08 PM
Superhawk996
The amperage is only part of the issue. The Bosc... Dec 10 2025, 02:13 PM
chmillman
If there is 6v on the yellow solenoid wire (ever)... Dec 10 2025, 03:11 PM
emerygt350 Many of us went from intermittent no start (as in ... Dec 10 2025, 04:06 PM
chmillman
Many of us went from intermittent no start (as in... Dec 10 2025, 04:14 PM
emerygt350
Many of us went from intermittent no start (as i... Dec 11 2025, 07:53 AM
914werke RE: Starter Wiring Dec 11 2025, 01:40 PM
barefoot
That's what I used, works just fine
Bar... Dec 13 2025, 07:56 AM
Blue Lightning
What current is the relay rated to? What gage i... Dec 14 2025, 08:08 PM
chmillman
What current is the relay rated to? What gage ... Dec 15 2025, 12:46 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 01:03 AM |
