| chmillman |
Oct 16 2025, 05:16 AM
Member ![]() ![]() Group: Members Posts: 356 Joined: 15-June 24 From: Switzerland Member No.: 28,183 Region Association: Europe
Thinking about replacing my stock horns with something like these (Hella T24):
https://www.amazon.de/HELLA-Frequenzbereich...urce=1&th=1 Various sites seem to indicate they will (physically) fit… They pull 72W each! So 12A total. The horn fuse is 16A, but it also runs the two 55W accessory driving lights in the bumper, which in my Euro spec car go on with the high beams. So imagine driving with the high beams on and having to honk… Only momentary, but that’s like a 21-22A draw thru that fuse. I guess in order to avoid this possibility, I am going to need an additional fuse and relay… Hmmm. |
| chmillman |
Oct 18 2025, 11:35 AM
Mostly I was interested in knowing if these things will actually fit in the same place as the OEM pancake horns - they being considerably thicker and the space behind the bumper being pretty limited.
| L-Jet914 |
Oct 19 2025, 08:00 PM
Member ![]() ![]() Group: Members Posts: 383 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
Mostly I was interested in knowing if these things will actually fit in the same place as the OEM pancake horns - they being considerably thicker and the space behind the bumper being pretty limited. I installed 96-97 VW Golf/Jetta high and low tone horns in my 914 in the stock two horn configuration locations. I used the factory female plugs from the golf/jetta and put spade connectors on the ends of the pigtail ends to connect to the factory locations in the 914 harness and the factory golf/jetta metal brackets. They sound amazing too. |
| porschetub |
Dec 10 2025, 03:06 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,029 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Mostly I was interested in knowing if these things will actually fit in the same place as the OEM pancake horns - they being considerably thicker and the space behind the bumper being pretty limited. I installed 96-97 VW Golf/Jetta high and low tone horns in my 914 in the stock two horn configuration locations. I used the factory female plugs from the golf/jetta and put spade connectors on the ends of the pigtail ends to connect to the factory locations in the 914 harness and the factory golf/jetta metal brackets. They sound amazing too. (IMG:style_emoticons/default/agree.gif) yes got mine off an early mk3 Golf ,liked the idea of the sealed connection plugs so used the female plugs and spliced then into the 914 wiring , nice and loud . |
chmillman Hella trumpet horns Oct 16 2025, 05:16 AM
rgalla9146 I want to run trumpet horns.
I have vintage on... Oct 16 2025, 07:14 AM
FlacaProductions Check Hella Supertones - depending on your reasons... Oct 16 2025, 08:57 AM
chmillman
Check Hella Supertones - depending on your reason... Oct 16 2025, 02:57 PM
jim_hoyland I have the high and low air horn. Each mounted beh... Oct 16 2025, 08:58 AM
porschetub
[quote name='chmillman' post='3228829' date='Oct ... Dec 10 2025, 03:07 PM
DC_neun_vierzehn
Mostly I was interested in knowing if these thin... Dec 10 2025, 04:34 PM
L-Jet914
[quote name='L-Jet914' post='3229011' date='... Dec 11 2025, 01:42 AM
chmillman So I finally installed a set of Hella Twin Tone ho... Dec 10 2025, 02:39 AM
bdstone914 @chmillman
You could swap the headlights to LED ... Dec 10 2025, 08:58 AM
chmillman
[b]@[url=http://www.914world.com/bbs2/index.php?s... Dec 10 2025, 12:16 PM
johnhora @chmillman
Do the Hella horns that you installed... Dec 10 2025, 03:19 PM
chmillman
Do the Hella horns that you installed have the ... Dec 10 2025, 03:52 PM
rgalla9146 I wanted the loudest horns that would fit the stoc... Dec 10 2025, 03:29 PM
Shivers I put them on pretty early in my ownership, it was... Dec 10 2025, 07:09 PM
DC_neun_vierzehn Cool. Thanks @L-Jet914 Dec 12 2025, 12:46 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 01:06 AM |
