> High Oil temperature, Concerned the temperature is getting to high too fast .
Ron914
post Dec 9 2025, 06:51 PM
In preparation and hope that I pass my smog test I want to go on the So. Cal.Toy Drive in my 914 on Saturday (not sure if this is a good idea) .
I need to address what I think might be a high oil temp problem .
After driving around town for 30 minutes the photo shows my oil temperature oil gauge and a actual thermometer reading using a turkey fryer thermometer.
The needle on my console gauge gets very close to the red high mark and sometimes just about to cross into the red .
At this point the turkey thermometer reads ~216 F degrees .
My Dakota Digital head cylinder temperature reads 111C (231F) .
It is almost 80F here today in sunny So Cal. but this seems too high for me . What would be a normal reading for the oil temp gauge?
This is a newly rebuilt motor (less than 300 miles on it).
I did not replace the oil cooler (its original) but it was flushed and was clear.
The baffles are held open by spring tension since the thermostat is not working but I checked they were open by removing the coil and checking through the bolt hole. This should be ok until I get a chance to replace it .
If I pass my smog check tomorrow or Thursday I am hesitant to take the car on a long canyon drive , so not sure if I can attend the toy drive this Saturday.
Any thoughts ?
emerygt350
post Dec 11 2025, 07:20 AM
I agree with the 50 weight hypothesis. I would try a cheap 30 weight synthetic. Go to walmart or something. Don't bother with the filter or anything.
Ron914   High Oil temperature   Dec 9 2025, 06:51 PM
brant   It’s not broke in yet It will come down if only ...   Dec 9 2025, 06:59 PM
worn   It’s not broke in yet It will come down if only...   Dec 9 2025, 07:03 PM
brant   It’s not broke in yet It will come down if onl...   Dec 10 2025, 04:18 PM
Ron914   It’s not broke in yet It will come down if only...   Dec 9 2025, 07:53 PM
Superhawk996   Do you have the stock 200c temp sensor?   Dec 9 2025, 07:38 PM
Ron914   Do you have the stock 200c temp sensor? Yes I do...   Dec 9 2025, 07:40 PM
Superhawk996   Do you have the stock 200c temp sensor? Yes I d...   Dec 9 2025, 07:47 PM
Ron914   [quote name='Ron914' post='3236265' date='Dec 9 2...   Dec 9 2025, 08:07 PM
bkrantz   10W-30 might be too thin.   Dec 9 2025, 08:01 PM
dtmehall   what does your oil pressure run cold/hot, idle/at ...   Dec 9 2025, 08:28 PM
Ron914   what does your oil pressure run cold/hot, idle/at...   Dec 9 2025, 08:39 PM
Superhawk996   When the engine is cold (as in overnight cold) it ...   Dec 9 2025, 08:51 PM
dtmehall   superhawk are you discounting that oil pressure m...   Dec 9 2025, 08:57 PM
Superhawk996   superhawk are you discounting that oil pressure ...   Dec 9 2025, 09:08 PM
dtmehall   :agree:   Dec 9 2025, 09:13 PM
Superhawk996   Posting this just for clarity on how temperature, ...   Dec 9 2025, 09:27 PM
Dave_Darling   The temp gauge on the center console is not super ...   Dec 10 2025, 02:45 AM
Geezer914   2056 motor, 9:1 cr., biral cylinders, Tangerine oi...   Dec 10 2025, 07:17 AM
930cabman   2056 motor, 9:1 cr., biral cylinders, Tangerine o...   Dec 10 2025, 04:03 PM
Geezer914   2056 motor, 9:1 cr., biral cylinders, Tangerine ...   Dec 10 2025, 04:39 PM
Ron914   [quote name='930cabman' post='3236378' date='Dec ...   Dec 11 2025, 08:59 AM
Ron914   2056 motor, 9:1 cr., biral cylinders, Tangerine ...   Dec 11 2025, 08:53 AM
Superhawk996   I need to find a dual sender so I can hook up the...   Dec 11 2025, 09:31 AM
930cabman   I need to find a dual sender so I can hook up th...   Dec 12 2025, 06:55 PM
emerygt350   I agree with the 50 weight hypothesis. I would tr...   Dec 11 2025, 07:20 AM
brant   Too early for synthetic I would put 1000 miles o...   Dec 11 2025, 07:28 AM
emerygt350   Too early for synthetic I would put 1000 miles ...   Dec 11 2025, 07:51 AM
Superhawk996   Because the receipt says oil pump and cover we kno...   Dec 11 2025, 09:39 AM
Superhawk996   I’m also going to write this for your benefit de...   Dec 11 2025, 09:49 AM
930cabman   I’m also going to write this for your benefit d...   Dec 11 2025, 10:23 AM
73-914   I’m also going to write this for your benefit d...   Dec 11 2025, 11:45 AM
JamesM   Tying to make an air cooled engines run at 180F...   Dec 11 2025, 09:44 PM
Ninja   I’m also going to write this for your benefit d...   Dec 11 2025, 03:29 PM
Ninja   Sorry, forum's been glitchy for me recently...   Dec 11 2025, 03:29 PM
Ron914   Sorry, forum's been glitchy for me recently.....   Dec 11 2025, 05:24 PM
emerygt350   Getting the oil over 210, as mentioned is importan...   Dec 11 2025, 03:46 PM
Ron914   I made a couple of more temperature readings when ...   Dec 11 2025, 06:24 PM
Superhawk996   Thoughts of abandoning this project are floating...   Dec 11 2025, 08:17 PM
emerygt350   I think the turkey thermometer is probably as good...   Dec 12 2025, 06:07 AM
930cabman   I think the turkey thermometer is probably as goo...   Dec 12 2025, 06:58 PM
Ninja   [quote name='Ninja' post='3236494' date='Dec 11 2...   Dec 13 2025, 01:55 PM
Ninja   The double post gremlin is very active with me now...   Dec 13 2025, 01:55 PM
- Lo-Fi Version Time is now: 3rd March 2026 - 01:04 AM
