> High Oil temperature, Concerned the temperature is getting to high too fast .
Ron914
post Dec 9 2025, 06:51 PM
In preparation and hope that I pass my smog test I want to go on the So. Cal.Toy Drive in my 914 on Saturday (not sure if this is a good idea) .
I need to address what I think might be a high oil temp problem .
After driving around town for 30 minutes the photo shows my oil temperature oil gauge and a actual thermometer reading using a turkey fryer thermometer.
The needle on my console gauge gets very close to the red high mark and sometimes just about to cross into the red .
At this point the turkey thermometer reads ~216 F degrees .
My Dakota Digital head cylinder temperature reads 111C (231F) .
It is almost 80F here today in sunny So Cal. but this seems too high for me . What would be a normal reading for the oil temp gauge?
This is a newly rebuilt motor (less than 300 miles on it).
I did not replace the oil cooler (its original) but it was flushed and was clear.
The baffles are held open by spring tension since the thermostat is not working but I checked they were open by removing the coil and checking through the bolt hole. This should be ok until I get a chance to replace it .
If I pass my smog check tomorrow or Thursday I am hesitant to take the car on a long canyon drive , so not sure if I can attend the toy drive this Saturday.
Any thoughts ?
Superhawk996
post Dec 11 2025, 09:49 AM
I’m also going to write this for your benefit despite the people I’m gonna piss off. (IMG:style_emoticons/default/stirthepot.gif)
216F isn’t even remotely close to too hot. Especially for an air cooled engine. Your modern daily driver will easily run 210-220 oil temp if heavily loaded, pulling up an extended grade (ie high load), or extended high speed (high aero load). During testing we wouldn’t even consider aborting at test until oil was well in excess of 250- 300F. Usually, a water pumper will overheat long before oil temperature cases a test to abort. For amusement . . . Go look on the Viper or Corvette forums and see what oil temps they run during a track day.
250F is absolutely zero concern for air cooled. Remember you have heads running at 350F and they are being cooled by oil - it should not be surprising that oil gets hot when washing over hot heads.
Yes, this necessitates reduced oil change intervals (3000 miles would be perfectly adequate) on air cooled engines. My air cooled motorcycles run this hot. We ran at these temperatures long before synthetics were a thing. Synthetics laugh at 250F.
There is a reason the oil temp redline is at 300F (back in the non-synthetic days) by engineers that actually design and test engines for a living vs what someone’s daddy or grand daddy taught them.
Tying to make an air cooled engines run at 180F oil temperature is counter productive.
There I said it (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/av-943.gif)
post Dec 11 2025, 11:45 AM
QUOTE(Superhawk996 @ Dec 11 2025, 10:49 AM) *
(IMG:style_emoticons/default/agree.gif) needs to be above 212 F (100 C) to evaporate condensation (IMG:style_emoticons/default/stirthepot.gif)
Ron914   High Oil temperature   Dec 9 2025, 06:51 PM
brant   It’s not broke in yet It will come down if only ...   Dec 9 2025, 06:59 PM
worn   It’s not broke in yet It will come down if only...   Dec 9 2025, 07:03 PM
brant   It’s not broke in yet It will come down if onl...   Dec 10 2025, 04:18 PM
Ron914   It’s not broke in yet It will come down if only...   Dec 9 2025, 07:53 PM
Superhawk996   Do you have the stock 200c temp sensor?   Dec 9 2025, 07:38 PM
Ron914   Do you have the stock 200c temp sensor? Yes I do...   Dec 9 2025, 07:40 PM
Superhawk996   Do you have the stock 200c temp sensor? Yes I d...   Dec 9 2025, 07:47 PM
Ron914   [quote name='Ron914' post='3236265' date='Dec 9 2...   Dec 9 2025, 08:07 PM
bkrantz   10W-30 might be too thin.   Dec 9 2025, 08:01 PM
dtmehall   what does your oil pressure run cold/hot, idle/at ...   Dec 9 2025, 08:28 PM
Ron914   what does your oil pressure run cold/hot, idle/at...   Dec 9 2025, 08:39 PM
Superhawk996   When the engine is cold (as in overnight cold) it ...   Dec 9 2025, 08:51 PM
dtmehall   superhawk are you discounting that oil pressure m...   Dec 9 2025, 08:57 PM
Superhawk996   superhawk are you discounting that oil pressure ...   Dec 9 2025, 09:08 PM
dtmehall   :agree:   Dec 9 2025, 09:13 PM
Superhawk996   Posting this just for clarity on how temperature, ...   Dec 9 2025, 09:27 PM
Dave_Darling   The temp gauge on the center console is not super ...   Dec 10 2025, 02:45 AM
Geezer914   2056 motor, 9:1 cr., biral cylinders, Tangerine oi...   Dec 10 2025, 07:17 AM
930cabman   2056 motor, 9:1 cr., biral cylinders, Tangerine o...   Dec 10 2025, 04:03 PM
Geezer914   2056 motor, 9:1 cr., biral cylinders, Tangerine ...   Dec 10 2025, 04:39 PM
Ron914   [quote name='930cabman' post='3236378' date='Dec ...   Dec 11 2025, 08:59 AM
Ron914   2056 motor, 9:1 cr., biral cylinders, Tangerine ...   Dec 11 2025, 08:53 AM
Superhawk996   I need to find a dual sender so I can hook up the...   Dec 11 2025, 09:31 AM
930cabman   I need to find a dual sender so I can hook up th...   Dec 12 2025, 06:55 PM
emerygt350   I agree with the 50 weight hypothesis. I would tr...   Dec 11 2025, 07:20 AM
brant   Too early for synthetic I would put 1000 miles o...   Dec 11 2025, 07:28 AM
emerygt350   Too early for synthetic I would put 1000 miles ...   Dec 11 2025, 07:51 AM
Superhawk996   Because the receipt says oil pump and cover we kno...   Dec 11 2025, 09:39 AM
Superhawk996   I’m also going to write this for your benefit de...   Dec 11 2025, 09:49 AM
930cabman   I’m also going to write this for your benefit d...   Dec 11 2025, 10:23 AM
73-914   I’m also going to write this for your benefit d...   Dec 11 2025, 11:45 AM
JamesM   Tying to make an air cooled engines run at 180F...   Dec 11 2025, 09:44 PM
Ninja   I’m also going to write this for your benefit d...   Dec 11 2025, 03:29 PM
Ninja   Sorry, forum's been glitchy for me recently...   Dec 11 2025, 03:29 PM
Ron914   Sorry, forum's been glitchy for me recently.....   Dec 11 2025, 05:24 PM
emerygt350   Getting the oil over 210, as mentioned is importan...   Dec 11 2025, 03:46 PM
Ron914   I made a couple of more temperature readings when ...   Dec 11 2025, 06:24 PM
Superhawk996   Thoughts of abandoning this project are floating...   Dec 11 2025, 08:17 PM
emerygt350   I think the turkey thermometer is probably as good...   Dec 12 2025, 06:07 AM
930cabman   I think the turkey thermometer is probably as goo...   Dec 12 2025, 06:58 PM
Ninja   [quote name='Ninja' post='3236494' date='Dec 11 2...   Dec 13 2025, 01:55 PM
Ninja   The double post gremlin is very active with me now...   Dec 13 2025, 01:55 PM
- Lo-Fi Version Time is now: 3rd March 2026 - 01:04 AM
