| Ron914 |
Dec 11 2025, 06:01 PM
Member ![]() ![]() Group: Members Posts: 492 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California
Well , I finally took the car in for a smog check today so I can complete my registration.
Not only did I fail but they refused to perform the check after I had spoke to them on 3 different occasions . I knew I was in trouble after pulling the car into the bay and the technician started eyeballing my car and said "What is it?" . I showed him the yellow USEPA sticker ,the doorsill Non-Catalyst sticker and my paper work .He replied "In 25 years of being a smog test technician he had never seen a car like this " . I replied well it's 50years old so maybe not . He then asked where the timing mark was after reading the sticker . I said it's under the air injection pump and they would have to remove it to see it ( well actually it doesn't show up and I need to use the flywheel mark. I told him I didn't have tools with me to remove the air cleaner and all the associated hosing . Now I checked with them before hand and they had a dyno and said no problem . Then he started backpedaling , Well I need to remove the cap on your fuel tank and pressure test it , and I will need to remove your air cleaner to check the timing ( didn't matter I had already told him I timed it to 27degrees BTDC @3500 RPM before I brought it too them and installed all the required smog /fuel injection equipment . He then told me I needed to take it somewhere else. (IMG:style_emoticons/default/sad.gif) So if anyone can recommend a qualified Smog shop near me (I live in Huntington Beach) I would appreciate it . Now related to my other post about high oil temperature . I was looking at the USEPA in the engine compartment and saw something interesting about the oil temperature. Is this the testing temperature for my smog test ? |
| sb914 |
Dec 12 2025, 06:45 AM
Surf Guru ![]() ![]() ![]() ![]() Group: Members Posts: 4,622 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California
Hey Ron,
You could move to Brookings. They don’t smog check here . (IMG:style_emoticons/default/beerchug.gif) |
Ron914 Ron's 1976 Dec 11 2025, 06:01 PM
Steve Have you looked into registering it as a classic c... Dec 11 2025, 06:18 PM
Montreal914 We're rooting for you Ron! :cheer:
Clear... Dec 11 2025, 09:24 PM
wonkipop yes, that is the oil temp for smog test.
in other ... Dec 11 2025, 11:32 PM
emerygt350 So disappointing. All that work just to get a guy... Dec 12 2025, 06:01 AM
Ron914
Hey Ron,
You could move to Brookings. They donâ€... Dec 12 2025, 11:24 AM
DennisV
So if anyone can recommend a qualified Smog shop ... Dec 12 2025, 09:31 AM
Ron914
So if anyone can recommend a qualified Smog shop... Dec 12 2025, 11:22 AM
Ron914
[quote name='Ron914' post='3236501' date='Dec 11... Dec 12 2025, 06:23 PM
DennisV
Thank you so much for that recommendation. Took m... Dec 13 2025, 08:06 AM
SO.O.C914er Dennis, Good lead as Yorktown and Beach is just ma... Dec 12 2025, 09:45 AM
fiacra I ran into the same problem when I had to smog my ... Dec 12 2025, 11:17 AM
Root_Werks What a PITA and agree, had to deal with pinheads b... Dec 12 2025, 05:09 PM
jim_hoyland Try Hans Imports, they do Smog. Hans used to own a... Dec 12 2025, 05:28 PM
porscheteck914 I am really surprised they let you pull the car in... Dec 12 2025, 05:50 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:04 PM |
