> SPITTING CARB - 914-6 all stock, **** Triangle of Items ****
ctc911ctc
post Oct 9 2025, 07:43 AM
1970 - 914-6 All stock
Got the car off the rack after a 1 year clean up documented here:
http://www.914world.com/bbs2/index.php?sho...3371&st=100
- tightened the lugs, check one more time for leaks.......
Car started first try, backed out of the driveway and went around the block
Drive strong.....very strong......
#2 cyl-carb is still 'spitting' definitely not backfiring. Chasing this through my trusty guide:
https://www.performanceoriented.com/special-procedures-1
See "notes" section
Seems that when I performed the Lean Best Idle procedure #2 failed during the procedure......the diagnosis within the document states that either the path in that carb #2 is blocked or the jet is the wrong size - my bet is a clog......though the carbs were very clean when I got the car.
There is a little noise from the right side, that in a 914-2L 4Cyl would be considered quiet, my hope is that it is not valve noise and may be exhaust leaking......did I tighten the heater manifold small nuts????? dry.gif
Carb advice sought from those that have chased a SPITTING Carb
brant
post Dec 14 2025, 10:36 AM
Measure the volume from the accelerator pump diagrams.
Then replace them most likely
They harden after a few years and reduce volume
This is a part of the carb setup that it sounds like you may have skipped
Then reset your timing. I agree with the above about the timing being off possibly
ctc911ctc   SPITTING CARB - 914-6 all stock   Oct 9 2025, 07:43 AM
Superhawk996   Unclear on the question here? You need to resolv...   Oct 9 2025, 08:41 AM
ctc911ctc   Thank you for the reply SH, I was more or less lo...   Oct 9 2025, 09:34 AM
slivel   Thank you for the reply SH, I was more or less l...   Oct 9 2025, 10:07 AM
Superhawk996   Anytime carbs are apart it’s good standard pract...   Oct 9 2025, 09:57 AM
infraredcalvin   Goes without saying - make sure valves are adjust...   Oct 9 2025, 11:15 AM
ctc911ctc   This is the exact guidance I was looking for, than...   Oct 9 2025, 10:42 AM
ctc911ctc   Less than 1 hour of run time between now and this ...   Oct 9 2025, 11:19 AM
Superhawk996   Less than 1 hour of run time between now and this...   Oct 9 2025, 11:46 AM
ctc911ctc   Understood - good solid engineering exercise.........   Oct 9 2025, 12:49 PM
930cabman   weak/broken valve spring? or some other issue wi...   Oct 9 2025, 12:49 PM
ctc911ctc   UPDATE!!!!!!! Teener...   Dec 13 2025, 02:28 PM
Cairo94507   I remember the 6's I've had that still has...   Dec 13 2025, 03:41 PM
rgalla9146   I just started (6pm) my dead stock 6 after it sat...   Dec 13 2025, 06:47 PM
fixer34   I just started (6pm) my dead stock 6 after it sa...   Dec 14 2025, 07:58 AM
mate914   I just started (6pm) my dead stock 6 after it s...   Dec 14 2025, 08:05 AM
930cabman   Guess I'm lucky to have a 914/6 conversion and...   Dec 14 2025, 10:16 AM
brant   Measure the volume from the accelerator pump diagr...   Dec 14 2025, 10:36 AM
gereed75   Agree with everything here except one thing- the h...   Dec 14 2025, 11:18 AM
930cabman   Agree with everything here except one thing- the ...   Dec 14 2025, 04:35 PM
ctc911ctc   Thank you all teeners for the replies, here are so...   Dec 14 2025, 08:24 PM
930cabman   Idle passageways plugged? drill/grind away the lea...   Dec 15 2025, 02:00 PM
ctc911ctc   Idle passageways plugged? drill/grind away the le...   Dec 15 2025, 02:51 PM
930cabman   Idle passageways plugged? drill/grind away the l...   Dec 15 2025, 02:57 PM
Ninja   Not hard to flush the circuits but if the critter ...   Dec 15 2025, 03:06 PM
930cabman   Not hard to flush the circuits but if the critter...   Dec 16 2025, 05:53 PM
ctc911ctc   Great notes Ninja, comments added within Not h...   Dec 16 2025, 07:38 PM
Ninja   Just re-read thread. You're stock so the origi...   Dec 15 2025, 04:02 PM
Ninja   Double post gremlin got me again!   Dec 15 2025, 04:02 PM
ctc911ctc   Hi, I came back to this car after a few major tri...   Feb 14 2026, 11:41 AM
porschetub   Hi, I came back to this car after a few major tr...   Feb 14 2026, 11:25 PM
ctc911ctc   Are those plugs any good they look old to me ? se...   Feb 15 2026, 03:01 PM
Superhawk996   here are the plugs – the 1,2,3 plugs look goo...   Feb 15 2026, 12:07 AM
Ninja   Clean plugs, check float levels, run again. If al...   Feb 14 2026, 02:01 PM
ctc911ctc   Thank you EVERYONE for contribution - this has bee...   Feb 15 2026, 02:37 PM
ctc911ctc   bump -   Feb 15 2026, 02:50 PM
Superhawk996   Fuel pressure isn’t going to be the problem lead...   Feb 15 2026, 02:54 PM
ctc911ctc   Superhawk - as always you come through. Soo, I sh...   Feb 15 2026, 02:59 PM
930cabman   Superhawk - as always you come through. Soo, I s...   Feb 16 2026, 05:57 AM
Superhawk996   There is one plug in there that doesn’t look “...   Feb 15 2026, 03:36 PM
rgalla9146   Don't trust the marking on jets. Get a jet ...   Feb 16 2026, 07:01 AM
ctc911ctc   *******UPDATE********* I was getting pretty frust...   Apr 4 2026, 09:28 PM
porschetub   *******UPDATE********* I was getting pretty frus...   Apr 5 2026, 12:13 AM
930cabman   All is well that ends well. but what could have be...   Apr 5 2026, 04:40 AM
brant   They need a full high end rebuild. Possibly butte...   Apr 6 2026, 10:25 AM
930cabman   They need a full high end rebuild. Possibly butt...   Apr 6 2026, 10:40 AM
Superhawk996   They need a full high end rebuild. Possibly butt...   Apr 6 2026, 07:58 PM
brant   An air leak is unmetered air and effects mixture a...   Apr 6 2026, 11:18 AM
ctc911ctc   ****UPDATE***** I have another thread that talks ...   Aug 27 2026, 06:05 PM
Superhawk996   :popcorn: Video looks like you might have gone b...   Aug 27 2026, 06:47 PM
ctc911ctc   :popcorn: Video looks like you might have gone ...   Aug 28 2026, 06:42 AM
Superhawk996   if i remove the play will I introduce binding or ...   Aug 28 2026, 07:28 AM
rgalla9146   If you hear a clacking noise at idle and it can be...   Aug 28 2026, 05:40 AM
ctc911ctc   UPDATE spent an hour Warmed the engine - still s...   Aug 28 2026, 02:24 PM
Superhawk996   I need to fix cyl 2 and 3 on the carb :agre...   Aug 28 2026, 09:11 PM
ctc911ctc   On my way to buy carb cleaner now - Question - s...   Aug 29 2026, 07:03 AM
brant   Spray carb cleaner on the loose idle shafts If th...   Aug 28 2026, 04:26 PM
ctc911ctc   ******NEW INFORMATION******** So, where we last l...   Sep 7 2026, 05:28 PM
Superhawk996   27 mm Venturis :wub: these are your best shot at ...   Sep 7 2026, 05:46 PM
ctc911ctc   Was hoping you would be on line! I watched ai...   Sep 7 2026, 05:58 PM
930cabman   :popcorn: carb popping is not uncommon with thes...   Sep 7 2026, 06:21 PM
Superhawk996   I’d bet money the bouncing of the throttle shaft...   Sep 7 2026, 06:41 PM
ctc911ctc   Tail of 2 sets of carbs I purchased a car with so...   Sep 14 2026, 06:17 PM
ctc911ctc   ***UPDATE*** I removed the Starboard carb and swa...   Sep 15 2026, 07:57 PM
Superhawk996   neighbors are a bot fussy about 914s and this mag...   Sep 15 2026, 08:06 PM
ctc911ctc   AAAAaaaannnnnddd the Lemon Tree! neighbors...   Sep 16 2026, 02:26 PM
ctc911ctc   OK, making progress, I put the carbs on the car t...   Sep 17 2026, 08:07 AM
brant   How is the side to side air meter numbers now? Wit...   Sep 17 2026, 08:25 AM
ctc911ctc   I synced side to side about 5ish, runs smoother. I...   Sep 17 2026, 06:24 PM
ctc911ctc   ******UPDATE****** Getting better, still bucking ...   Oct 4 2026, 07:19 PM
sixnotfour   3 Half Turns equals 1-1/2 Turns.   Oct 4 2026, 08:41 PM
Superhawk996   I’ll go back and read all of Performance Oriente...   Oct 5 2026, 12:33 AM
Superhawk996   Page 56 from Weber Tuning Manual See the highligh...   Oct 5 2026, 01:05 AM
Superhawk996   Here’s the cutaway (from IDF guide) that shows y...   Oct 5 2026, 01:09 AM
Superhawk996   School of hard knocks stuff going on here but youâ...   Oct 5 2026, 01:38 AM
930cabman   Crazy as it sounds, I have had luck opening each a...   Oct 5 2026, 07:14 AM
ctc911ctc   @superhawk - thank you for the detailed reply, VER...   Oct 5 2026, 08:08 AM
Superhawk996   Here is my problem - I understand the theory and...   Oct 5 2026, 10:04 AM
Superhawk996   Yeah, sorry had I known what you were doing we sho...   Oct 5 2026, 09:53 AM
ctc911ctc   Lots of travel ahead, may be 10 days for an update   Oct 5 2026, 07:16 PM
Superhawk996   Lots of travel ahead, may be 10 days for an updat...   Oct 5 2026, 08:16 PM
ctc911ctc   ***UPDATE*** I performed the following runs reall...   Oct 22 2026, 02:26 PM
Superhawk996   I interpret this as I should in every cylinder b...   Oct 22 2026, 03:20 PM
Superhawk996   What happens if you disconnect spark plug wire fro...   Oct 22 2026, 03:14 PM
Superhawk996   This whole process of best lean, set idle speed, b...   Oct 22 2026, 04:27 PM
- Lo-Fi Version Time is now: 22nd October 2026 - 07:48 PM
