| david63 |
Dec 13 2025, 11:25 PM
Member ![]() ![]() Group: Members Posts: 98 Joined: 9-August 09 From: Parker Colorado Member No.: 10,653 Region Association: Rocky Mountains |
Searched through threads for a bit and didn’t see anything referencing swapping a 718 cayman 4 cylinder turbo motor into a 914. I imagine in the near future these engines will start showing up for sale from wrecked cars, etc.
Realize that it is water cooled so cooling would require a radiator like the unit Renegade hybrids sells. Will need to get air flow to the turbo. Also lots of questions about if the engine will physically fit in the 914. Wiring, ECU’s, transaxle, on and on. I get it, it would require a lot of fabrication. The price of doing a 6 cylinder conversion is straightforward but getting pretty expensive. The turbo 4 cylinder motors advertise over 300 hp at the crank and it would be cool to have a 914 with a 4 cylinder high horsepower motor. I bet someone has already done this I just haven’t found anything. Who knows, someday this may be a common swap…. What do y’all think about this idea? |
| Ninja |
Dec 14 2025, 05:34 PM
Member ![]() ![]() Group: Members Posts: 55 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
This is one of the swaps I considered.
When swapping to a modern can-bus controlled vehicle drivetrain it's easiest to start with a functional complete vehicle. It will save $$$$ and TIME heading back to the salvage yard for yet another critical piece of wiring or black box... The GM LGX V6 "Alfa" platform is my current choice for a 914 drivetrain. This will require a custom engine to trans adaptor that no one makes now. I would use a 986/987 manual transmission. Second (mainly due to cost) would be the 718 PDK. If you stayed with the entry level 718 the 2.0L badges would be correct! Third choice for me is a 986/987/981. I've seen (not in person) both 986 and 987 conversions "complete". Here's one that was recently on BAT. https://bringatrailer.com/listing/1970-porsche-914-40-2/ Pre-2000 are the simplest versions for conversion. They went electronic throttle post that point along with further complexity. The year 2000 is usually the point of significant can-bus "complexity" in most of the car brands. That BAT car shows the tightness on the inboard suspension mounts. Worth looking at for ideas. Any of the above really require a functional donor. I don't have a 718 or a base 16+ Camaro but I DO have a functional (roached) 99 2.5 Boxster! I believe the 718 engine is too wide for the stock rear suspension but the wheel base is damn close to the same and I could see a 914 BODY swap onto a 718 chassis as being a possibility. Keep all of the modern sports car but make it look "similar" to the old. Sort of like this. If I won the lottery I'd order one of these just to have it... https://www.carscoops.com/2025/10/no-this-i...ext-best-thing/ @wonkipop DFI started in the 08 Boxster S and spread quickly to the other models. I'd choose DFI over port any day! I'd EXPECT to rip off the intake manifold and clean the carbon every 50k or so... 50k could be a LONG time on a secondary "fun" vehicle. The fuel in the intake charge takes up approximately 9% of the available volume and injecting it directly is ALWAYS worth more than 10% power increase with a bunch of other benefits. Now, carboning up the intake valves IS a real issue! Multiple manufactures have added the port injectors back in (has both port and DFI now) to solve it. |
david63 718 cayman engine swap Dec 13 2025, 11:25 PM
Front yard mechanic Just 30k shy of trying this :driving-girl: Dec 14 2025, 10:04 AM
Mitox Very cool expensive idea. Go for it, so we can wa... Dec 14 2025, 10:35 AM
SirAndy Looking at some pictures of the engine online, the... Dec 14 2025, 10:38 AM
worn
Looking at some pictures of the engine online, th... Dec 15 2025, 06:32 PM
mepstein If it's your passion to do the swap, go for it... Dec 14 2025, 11:11 AM
wonkipop could be wrong but pretty sure 718 4 is direct inj... Dec 14 2025, 03:19 PM
could be wrong but pretty sure 718 4 is direct in... Dec 14 2025, 05:26 PM
wonkipop
could be wrong but pretty sure 718 4 is direct i... Dec 14 2025, 05:54 PM
bkrantz
could be wrong but pretty sure 718 4 is direct i... Dec 15 2025, 08:44 PM
scallyk9 Check out the 914 with an early Boxster engine tha... Dec 14 2025, 10:28 PM
Steve I rented a 718 Cayman S in Germany. The turbo lag... Dec 15 2025, 08:31 PM
rgalla9146 Anyone consider a '04 R32 (240 hp) 6 speed ?
... Dec 15 2025, 10:23 PM
targa72e Doing a air cooled 6 swap is the easiest (not the ... Dec 15 2025, 10:47 PM
Kraftwerk Guy from Quebec who bought my car years ago claime... Dec 15 2025, 11:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th December 2025 - 05:06 AM |
