> Starter Wiring, Why doesn't my car look like all the others?!?
Blue Lightning
post Dec 7 2025, 04:47 PM
1976 2.0. Putting engine back in after a 2056-dectomy, but it has been out too long and as usual I didn't take enough pictures of all the important connections.
There are many threads on wiring for the starter. However, I have one additional wire that I don't see in any of those threads, but I marked as going to the starter solenoid.
Wire in my hand:
Way off to right:
Out of focus in center:
The wire in question is red and has a spade terminal on the end. It is not the cable that runs from the alternator. My best guess as of today is that is leads up to the firewall and goes through here:
Thoughts? Car has air conditioning, so is this part of that?
Literati914
post Dec 9 2025, 03:22 PM
You got it looking like this (see pic) at the Solenoid? I can not tell from your pics.. but "Solenoid" is written on your tape notes.
Blue Lightning
post Dec 14 2025, 07:42 PM
QUOTE(Literati914 @ Dec 9 2025, 04:22 PM) *
I believe I have it wired like shown (I used the diagrams and pictures Mark Henry had in his thread). This was my first time pulling the engine from the car, and it is possible that I put the label on after removing it (as in I forgot to disconnect it before dropping and did it while it was sitting under the car still attached or detached).
Blue Lightning   Starter Wiring   Dec 7 2025, 04:47 PM
Jack Standz   Your car looks different because it's been mod...   Dec 7 2025, 06:27 PM
Blue Lightning   Your car looks different because it's been mo...   Dec 7 2025, 09:33 PM
Rob-O   Follow it through the engine tin. Where does it g...   Dec 8 2025, 09:54 AM
Blue Lightning   Follow it through the engine tin. Where does it ...   Dec 8 2025, 01:46 PM
Dlee6205   Agreed my car has the "hot start" mod....   Dec 8 2025, 02:05 PM
Blue Lightning   The answer to your question is we don't know....   Dec 8 2025, 03:52 PM
Spoke   1976 2.0. Putting engine back in after a 2056-de...   Dec 8 2025, 02:42 PM
Dlee6205   I just saw where you said your car has AC... its e...   Dec 8 2025, 03:09 PM
emerygt350   That is a beefy wire. The mod grounds to the case...   Dec 8 2025, 06:51 PM
Blue Lightning   That is a beefy wire. The mod grounds to the cas...   Dec 9 2025, 07:45 AM
930cabman   Waay to messy for me, I would lose the Ford relay ...   Dec 8 2025, 06:54 PM
Blue Lightning   Waay to messy for me, I would lose the Ford relay...   Dec 9 2025, 07:47 AM
Blue Lightning   :sawzall:   Dec 9 2025, 08:01 AM
emerygt350   But doesn't address the problem of the mystery...   Dec 9 2025, 06:00 AM
emerygt350   Hopefully you would use a relay but maybe they wer...   Dec 9 2025, 02:49 PM
emerygt350   Check the resistance on it and maybe send 12v? Ki...   Dec 9 2025, 02:50 PM
Literati914   You got it looking like this (see pic) at the Sole...   Dec 9 2025, 03:22 PM
Blue Lightning   You got it looking like this (see pic) at the Sol...   Dec 14 2025, 07:42 PM
emerygt350   Just tried staring at your picture again. I think...   Dec 9 2025, 05:43 PM
Blue Lightning   Just tried staring at your picture again. I thin...   Dec 14 2025, 07:44 PM
chmillman   How much current does the original solenoid draw a...   Dec 10 2025, 05:00 AM
Superhawk996   How much current does the original solenoid draw ...   Dec 10 2025, 09:23 AM
chmillman   [quote name='chmillman' post='3236299' date='Dec ...   Dec 10 2025, 09:47 AM
Superhawk996   The solenoid or the starter...??? I can't ...   Dec 10 2025, 09:49 AM
chmillman   I’ve measured it with an accurate shunt resisto...   Dec 10 2025, 11:37 AM
Blue Lightning   How much current does the original solenoid draw...   Dec 14 2025, 07:57 PM
Spoke   Found this schematic for the Ford relay conversion...   Dec 10 2025, 09:03 AM
Superhawk996   In response to OP original question - you’re go...   Dec 10 2025, 09:26 AM
emerygt350   The amperage is only part of the issue. The Bosch...   Dec 10 2025, 01:08 PM
Superhawk996   The amperage is only part of the issue. The Bosc...   Dec 10 2025, 02:13 PM
chmillman   If there is 6v on the yellow solenoid wire (ever)...   Dec 10 2025, 03:11 PM
emerygt350   Many of us went from intermittent no start (as in ...   Dec 10 2025, 04:06 PM
chmillman   Many of us went from intermittent no start (as in...   Dec 10 2025, 04:14 PM
emerygt350   Many of us went from intermittent no start (as i...   Dec 11 2025, 07:53 AM
914werke   RE: Starter Wiring   Dec 11 2025, 01:40 PM
barefoot   That's what I used, works just fine Bar...   Dec 13 2025, 07:56 AM
Blue Lightning   What current is the relay rated to? What gage i...   Dec 14 2025, 08:08 PM
chmillman   What current is the relay rated to? What gage ...   Dec 15 2025, 12:46 AM
- Lo-Fi Version Time is now: 3rd March 2026 - 01:04 AM
