> 718 cayman engine swap, Will the 4 cylinder turbo engine physically fit in a 914
david63
post Dec 13 2025, 11:25 PM
Searched through threads for a bit and didn’t see anything referencing swapping a 718 cayman 4 cylinder turbo motor into a 914. I imagine in the near future these engines will start showing up for sale from wrecked cars, etc.
Realize that it is water cooled so cooling would require a radiator like the unit Renegade hybrids sells. Will need to get air flow to the turbo. Also lots of questions about if the engine will physically fit in the 914. Wiring, ECU’s, transaxle, on and on. I get it, it would require a lot of fabrication.
The price of doing a 6 cylinder conversion is straightforward but getting pretty expensive.
The turbo 4 cylinder motors advertise over 300 hp at the crank and it would be cool to have a 914 with a 4 cylinder high horsepower motor.
I bet someone has already done this I just haven’t found anything. Who knows, someday this may be a common swap….
What do y’all think about this idea?
rgalla9146
post Dec 15 2025, 10:23 PM
Anyone consider a '04 R32 (240 hp) 6 speed ?
plenty out there, engine in front of axles and has to carry a THOUSAND fewer pounds.
Plus a little reverse heritage.
TheRuttmeister
post Dec 16 2025, 07:05 PM
QUOTE(rgalla9146 @ Dec 15 2025, 08:23 PM) *
The Golf?
You can't use the FWD transmission (unless you are ok with deleting the boot and moving the CG backwards and up a lot, and building a structure to carry all that). So then you are looking at anything that will mount to a boxster 5 speed. Yes the VR6 might be a bolt-on and is going to be simple to fit because its so tiny... But its not... an amazing, engine. Not when you can fit a so many other options in there.
Don't get me wrong, it would be cool to see... but I don't think there's a huge cross-over between the GTI crowd and 914 owners.
(owns a GTI and a 914).
VaccaRabite
post Dec 17 2025, 09:06 AM
En Garde!
QUOTE(TheRuttmeister @ Dec 16 2025, 08:05 PM) *
The Golf?
More then you think I think.
I have a GLI, Rabbit and 914.
The engine is a great engine, and there are adapters you can get to mate the ea888 to different transmissions in a longitudinal instead of transverse orientation. I know the initial comment was about the GTi 6 speed - and I agree thats a tall order. But the engine is certainly possible. Not an easy swap though. All the modern engines live and die by the ECU, so you have to adapt all that in - either the stock unit or program something custom.
Zach
david63   718 cayman engine swap   Dec 13 2025, 11:25 PM
Front yard mechanic   Just 30k shy of trying this :driving-girl:   Dec 14 2025, 10:04 AM
Mitox   Very cool expensive idea. Go for it, so we can wa...   Dec 14 2025, 10:35 AM
SirAndy   Looking at some pictures of the engine online, the...   Dec 14 2025, 10:38 AM
worn   Looking at some pictures of the engine online, th...   Dec 15 2025, 06:32 PM
mepstein   If it's your passion to do the swap, go for it...   Dec 14 2025, 11:11 AM
wonkipop   could be wrong but pretty sure 718 4 is direct inj...   Dec 14 2025, 03:19 PM
mepstein   could be wrong but pretty sure 718 4 is direct in...   Dec 14 2025, 05:26 PM
wonkipop   could be wrong but pretty sure 718 4 is direct i...   Dec 14 2025, 05:54 PM
bkrantz   could be wrong but pretty sure 718 4 is direct i...   Dec 15 2025, 08:44 PM
SirAndy   [quote name='mepstein' post='3236891' date='Dec 14...   Dec 16 2025, 04:48 PM
bkrantz   [quote name='mepstein' post='3236891' date='Dec 1...   Dec 16 2025, 07:50 PM
mepstein   [quote name='SirAndy' post='3237115' date='Dec 16...   Dec 17 2025, 05:46 AM
Spoke   I believe they are $80-100k now. Yikes...   Dec 16 2025, 10:38 AM
Ninja   This is one of the swaps I considered. When swapp...   Dec 14 2025, 05:34 PM
scallyk9   Check out the 914 with an early Boxster engine tha...   Dec 14 2025, 10:28 PM
Steve   I rented a 718 Cayman S in Germany. The turbo lag...   Dec 15 2025, 08:31 PM
rgalla9146   Anyone consider a '04 R32 (240 hp) 6 speed ? ...   Dec 15 2025, 10:23 PM
TheRuttmeister   Anyone consider a '04 R32 (240 hp) 6 speed ?...   Dec 16 2025, 07:05 PM
VaccaRabite   The Golf? You can't use the FWD transmissi...   Dec 17 2025, 09:06 AM
targa72e   Doing a air cooled 6 swap is the easiest (not the ...   Dec 15 2025, 10:47 PM
Kraftwerk   Guy from Quebec who bought my car years ago claime...   Dec 15 2025, 11:55 PM
TRP   Someone just sold a boxster 2.7 swapped 914 on BAT...   Dec 17 2025, 05:47 PM
TheRuttmeister   *SNIP* The engine is a great engine... ea888......   Dec 18 2025, 01:27 PM
5 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 18th December 2025 - 05:21 PM
