| chmillman |
Dec 16 2025, 04:28 PM
Member ![]() ![]() Group: Members Posts: 369 Joined: 15-June 24 From: Switzerland Member No.: 28,183 Region Association: Europe
I have a very slight oil leak that appears to be coming out of the small notch at the joint between the motor and the transmission. It's really nothing that I'm worried about, every once in awhile there is a drop on the floor... I was just curious, does this indicate that the crankshaft main seal is leaking, or it it the transmission? |
| bkrantz |
Dec 17 2025, 08:39 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,646 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
I have a very slight oil leak that appears to be coming out of the small notch at the joint between the motor and the transmission. It's really nothing that I'm worried about, every once in awhile there is a drop on the floor... I was just curious, does this indicate that the crankshaft main seal is leaking, or it it the transmission? One other possibility: one of the galley plugs on the rear of the engine case, under the flywheel, is leaking. That might be better or worse news. Either way you need to remove the flywheel to check (and fix). |
chmillman Very slight oil leak... Dec 16 2025, 04:28 PM
Superhawk996 Taste it . . . :barf:
:evilgrin:
But serious... Dec 16 2025, 04:37 PM
chmillman
:evilgrin:
But seriou... Dec 16 2025, 04:47 PM
Superhawk996
I do know what 90 weight smells like, . . .
Ver... Dec 16 2025, 05:21 PM
porschetub Looks like RMS to me however is it dripping out th... Dec 16 2025, 07:45 PM
Jack Standz RMS. Just had this same issue, but since we use S... Dec 16 2025, 08:41 PM
bkrantz
RMS. Just had this same issue, but since we use ... Dec 17 2025, 08:37 PM
wonkipop take it for a good long drive.
300-400km round tri... Dec 17 2025, 04:13 AM
bkrantz
I have a very slight oil leak that appears to ... Dec 17 2025, 08:39 PM
Jack Standz
[quote name='Jack Standz' post='3237156' date='De... Dec 17 2025, 09:27 PM
Jack Standz
I have a very slight oil leak that appears to ... Dec 17 2025, 09:32 PM
rudedude I’ve taken the transmission out of my /6 to chan... Dec 18 2025, 08:39 AM
BillC
I’ve taken the transmission out of my /6 to cha... Dec 18 2025, 10:46 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:16 PM |
