> Very slight oil leak..., Is this coming from the rear main seal?
chmillman
post Dec 16 2025, 04:28 PM
Region Association: Europe
I have a very slight oil leak that appears to be coming out of the small notch at the joint between the motor and the transmission. It's really nothing that I'm worried about, every once in awhile there is a drop on the floor... I was just curious, does this indicate that the crankshaft main seal is leaking, or it it the transmission?
bkrantz
post Dec 17 2025, 08:39 PM
QUOTE(chmillman @ Dec 16 2025, 03:28 PM) *
One other possibility: one of the galley plugs on the rear of the engine case, under the flywheel, is leaking. That might be better or worse news. Either way you need to remove the flywheel to check (and fix).
- Lo-Fi Version Time is now: 2nd April 2026 - 01:46 PM
